The Dell SonicWALL SuperMassive 9000 series Next-Generation Firewall (NGFW) is designed to deliver deep security to your enterprise at multi-gigabit speeds. Offering the ultimate in security with enterprise class performance, the SuperMassive 9000 series detects and blocks the most sophisticated threats before they can enter your network with minimal latency for every connection on the network. Utilizing a higher core density architecture in an elegant, one rack unit appliance, the SuperMassive 9000 series efficiently saves rack space and lowers power and cooling costs. Its multicore design can gracefully handle traffic spikes without impacting network performance.
Now your enterprise can be both secure and productive. Dell turned the network security product category upside down by redefining the Next-Generation Firewall and eliminating the age-old protection-for-performance tradeoff. Dell SonicWALL SuperMassive series was designed from the ground up for the world's most demanding enterprise networks. Culminating from years of research and development, the solution was built to deliver security, performance, and scalability without compromise.
Next-generation firewall
Tightly integrated with Reassembly-Free Deep Packet Inspection to deliver intrusion prevention, malware protection, application intelligence, control and visualization, and inspection for SSL encrypted sessions. They scan every byte of every packet for the deepest level of protection and massively scale to extend state-of-the-art security to growing and distributed enterprise networks. -
Application intelligence
SonicWall provides real-time insight and control of network traffic broken down by applications, users and content. The ability to prioritize important applications, throttle down unproductive applications and block unwanted application components ensures an efficient and safe network. -
Intrusion prevention
Tightly integrated, signature based network intrusion prevention protects against a comprehensive array of network and application layer threats by scanning packet payloads for attacks and exploits targeting critical internal systems. -
Deep Packet Inspection for SSL encrypted traffic (DPI-SSL)
DPI-SSL transparently decrypts, inspects and re-encrypts SSL encrypted traffic to allow security services to be applied to all traffic that traverses SonicWall Next-Generation Firewalls. -
SonicWall Mobile Connect
SonicWall Mobile Connect, a single unified client app for Apple iOS and Google Android, provides smartphone and tablet users superior network-level access to corporate and academic resources over encrypted SSL VPN connections. -
High performance
SonicWall's patented Reassembly-Free Deep Packet Inspection engine combined with up to 32 processing cores ensures that the 9000 Series is capable of inspecting over one million connections simultaneously across all ports. With nearly zero latency and without file size limitations, the system provides more than 10 Gbps of full deep packet inspection throughput across 4 x 10-GbE SFP+, 8 x 1-GbE SFP, 8 x 1-GbE interfaces. Designed with power, space and cooling (PSC) in mind, SuperMassive provides the leading Gbps/Watt in the industry. -
Deep packet inspection firewall
SonicWall Reassembly-Free Deep Packet Inspection technology scans against multiple application types and protocols to protect against internal and external threats at both the application layer and the network layer. -
Virtual private networking
High-performance Virtual Private Networks (VPNs) easily scale to thousands of end points and branch offices. And SonicWall Clean VPN technology protects the integrity of both your IPSec and SSL VPN traffic, securing your remote access tunnels and decontaminating the traffic running over it. -
SSL VPN remote access
Integrated SSL VPN technology enables clientless, remote access to email, files, intranets, and applications from a variety of tablet, phone and PC platforms. The SSL VPN client can also be automatically pushed out to the client and auto-configured to provide secure layer 3 connectivity. -
Intuitive management
Powerful set-up wizards make it easy to quickly set up VPN Tunnels, policies and network rules, which can then be fine-tuned through an intuitive Web interface. All application and signature updates are obtained automatically by the firewall and are effective immediately without reboots or downtime. -
Powerful reporting
Historical reporting on user activity is available through SonicWall Analyzer software and real-time application analysis through powerful visualization tools. -
Advanced clustering
Select firewall models support a number of advanced deployment scenarios for increased throughput and redundancy beyond the common active/passive and active/active two unit deployments. Active/Active clustering deployments allow for assembly of stateful HA pair, stateless-HA pairs and single-unit "nodes" within the cluster. A Cluster can consist of up to 4 nodes, each node containing one or two units, for distribution of flows across all nodes with linear performance scaling. -
WAN acceleration
Add a SonicWall WAN Acceleration Appliance (WXA) to a SonicWall firewall to significantly enhance WAN application performance. This integrated solution simplifies deployment, configuration, routing and management by uniquely synergizing network security with network optimization. -
URL filtering
SonicWall content filtering service blocks multiple categories of objectionable Web content and provides the ideal combination of control and flexibility to ensure the highest levels of productivity and protection.
- SonicWall SuperMassive 9200 - security appliance
- Security appliance
- Form Factor
- Rack-mountable - 1U
- RAM
- 8 GB
- Data Link Protocol
- Gigabit Ethernet, 10 Gigabit Ethernet
- Performance
- Firewall throughput: 15 Gbps , Application throughput: 5 Gbps , IPS throughput: 5 Gbps , Anti-malware throughput: 3.5 Gbps , VPN throughput: 5 Gbps , Forwarding performance (IMIX): 4.4 Gbps
- Capacity
- Maximum application cores: 24 , VPN tunnels (site-to-site): 6000 , VPN client licences: 2000 , SSL VPN tunnels: 2 , Virtual interfaces (VLANs): 512 , Connection / user qty: 1250000 , DPI connections: 1000000
- VoIP Protocols
- H.323, SIP
- Power
- AC 120/230 V (50/60 Hz)
- 43.3 cm x 48.5 cm x 4.5 cm
- 8.2 kg
- Height (Rack Units)
- 1U
- Built-in Devices
- Status LCD
- 43.3 cm
- 48.5 cm
- 4.5 cm
- 8.2 kg
Processor / Memory / Storage
- RAM
- 8 GB
- Form Factor
- Rack-mountable
- Connectivity Technology
- Wired
- TCP/IP, PPTP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS, CLI
- Performance
- Capacity
- Status Indicators
- Power, test mode, alarm
- NAT support, VPN support, load balancing, LDAP support, Stateful Packet Inspection (SPI), DoS attack prevention, manageable, High Availability, Intrusion Prevention System (IPS), URL filtering, Deep Packet Inspection (DPI), DDos attack prevention, anti-malware protection, Quality of Service (QoS), RADIUS support, DHCP server, reset button, bandwidth control, hot swappable dual fans, Link Aggregation Control Protocol (LACP), NetFlow, IPFIX
- Encryption Algorithm
- DES, Triple DES, MD5, SHA-1, FIPS 140-2, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, LDAP, Active Directory, XAUTH authentication
- IEEE 802.1p
IP Telephony
- VoIP Protocols
- H.323, SIP
Communications
- Supported Flash Memory Cards
- SDHC Memory Card
- Expansion Slots
- 1 (total) / 1 (free) x expansion slot
- 1 x 1000Base-T (management) - RJ-45 , 2 x USB - Type A , 1 x management - RJ-45 , 8 x 1000Base-T - RJ-45 , 8 x 1000Base-X - SFP (mini-GBIC) , 4 x 10GBase-X - SFP+
- Cables Included
- 1 x network cable , 1 x serial cable
- Rack Mounting Kit
- Included
- FCC Class A certified, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, NOM, CB, RoHS, KCC, WEEE, ANATEL
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- 300 Watt
- OS Provided
- SonicOS
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
