The Somfy GDK 700 allows you to operate your automated garage doors from the comfort of your car. When you're near your garage doors, simply use the remote control to open and close them, meaning you won't have to face the elements.
The unique belt transmission ensures silent operation without compromising on its strength or ease of use. The whisper quiet opening and closing function, alongside its soft start/stop system, means you never have to worry about disturbing your family members when you arrive home late.
This easy to install device also features 700Nm lifting capabilities, making it ideal for garage doors up to 70 kg and 7 m2. With its built in lighting, obstacle detection and burglar protection, the GDK 700 ensures security and easy access at all times.
- Somfy GDK 700 - garage door opener - Radio Technology Somfy (RTS)
- Product Type
- Garage door opener
- Package Content
- 2 x remote controls
- Connectivity
- Wireless - Radio Technology Somfy (RTS)
- Frequency Band
- 433.42 MHz
- 5-year warranty
- Product Type
- Package Content
- Connectivity Technology
- Wireless
- Frequency Band
- 433.42 MHz
- Nominal Voltage
- AC 230V
- Warranty
- 5-year warranty
- 120 Watt
- -20 °C
- 60 °C
