The CHS 7Qi is a wireless barcode scanner certified by Apple for iOS devices. Also compatible with Android and Windows smartphones and tablets,
Minimize manual data entry with the Socket CHS 7Qi, a portable 2D and 1D barcode scanner certified by Apple for the iPad, iPad mini, iPhone and iPod touch. Small, lightweight and comfortable to hold, the CHS 7Qi connects wirelessly to the smartphones and tablets and can scan barcodes printed on labels or displayed on device screens. It's ideal for retail point of sale, inventory management, and other mobile scanning applications.
- Socket Cordless Hand Scanner (CHS) 7Qi - barcode scanner
- Barcode scanner - portable - Bluetooth 2.1 EDR - decoded
- White
- Minimum Bar Width
- 5 mil
- Scan Element Type
- 2D imager
- Connectivity Technology
- Wireless
- Wireless Connectivity
- Bluetooth 2.1 EDR
- Battery
- 2 x AAA type - Nickel Metal Hydride
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Mobile, Android, Apple iOS
- 3.5 cm x 12.9 cm x 4 cm
- 45 g
- 1-year warranty
- White
Barcode
- Interface Type
- Bluetooth 2.1 EDR
- Minimum Bar Width
- 5 mil
- Scan Element Type
- 2D imager
- Max Working Distance
- 50.8 cm
- Print Contrast Signal (PCS)
- 20%
- Decode Capability
- Code 93, Matrix 2 of 5, Code 39, UCC/EAN-128, ISBT 128, GS1 DataBar, Bookland, EAN/JAN-13, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, Plessey, ISSN, ITF-14
- TTL Decoding
- Decoded
- Wireless
- OK Notification
- Vibration
- Bluetooth 2.1 EDR
- Included Accessories
- Lanyard/belt clip with retractable tether
- C-Tick, EN55022, ICES-003, EN55024, Bluetooth Class 1, CISPR 22, RSS-210, FCC Part 15 C, CSA C22.2, RoHS, UL 60950-1, IEC 60950-1, IEC 60825-1, TELEC, EN 60825-1
- Power Device
- Power adapter - external
- Battery
- 2 x Nickel Metal Hydride - AAA type
Software
- Software Included
- Drivers & Utilities, SocketScan
- OS Required
- 3.5 cm
- 12.9 cm
- 4 cm
- 45 g
- Limited warranty - 1 year
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
- Drop Specification
- 1.2 m to concrete
