snom 821 Black SIP IP Phone
Quicklinx: 7K7SWS00 Mfr#: 00002346
The 8 Experience
The snom 820 was a decisive step towards combining state-of-the-art technology with a new design. It was the beginning of a superior line of business VoIP phones. Its extraordinary elegance and performance combined both: latest technology and well-known snom features.
At CeBIT 2010 we took hardware development a step further: Like its big brother, the snom 870, the snom 821 comes equipped with an integrated 1-gigabit switch. And, also like the snom 870, the snom 821 is available in black and in gray.
Main features
  • High-resolution TFT color display (8,9 cm (3,5 inch) 320 x 240pxl)
  • Integrated 1 Gigabit switch
  • Comfortable and intuitive menu structure
  • 5-way conferencing (bridge on phone)
  • Caller identification on display Directory (250 entries)
  • Import/export of directory/phonebook
  • Speed dial
  • Local dial plan
  • Codecs: G.711, G.729A, G.723.1, G.722, G.726, GSM 6.10 (Full rate)
  • Lists of missed, received, and dialed calls (100 entries each)
  • Indication of calls on hold
  • Clock with automatic daylight-saving time, call timer
  • Call blocking (deny list)
  • Handling of up to 12 calls simultaneously
  • Available colours: light grey, black
Design
The snom 821 replaces the snom 820 as the entry model of a new generation of snom VoIP business phones. With this new 8xx series, currently consisting of the snom 821 and the snom 870, two main requirements of modern telephony are realized without compromises in one device: mature VoIP technology and a design in a class of its own.
Display and Wideband technology
With its large high-resolution TFT color display (8,9 cm (3.5 inch), 320 x 240 pixels) the snom 821 offers a brilliant depiction of call lists, phone directories, and caller information via the integrated XML browser.
The wideband technology used in the handset captures more than double the frequency spectrum that a standard handset does, making the audio quality comparable to FM radio. On speakerphone a Class D amplifier reliably suppresses interference noise.
WLAN and Security
The snom 821 WLAN gives you complete freedom in selecting the environment of your choice. Whichever option you prefer, the snom 821 is prepared for any and all scenarios: Power via adapter plus WLAN or Power-over-Ethernet (PoE).
Moreover, the snom 821 offers all conveniences snom customers have come to expect from us. As security is one of the most important concerns of our time, this topic has always been a priority for snom. Therefore important security features like secure VPN, TLS and SRTP are an integral part of the 821's firmware. Our continuing goal is to ensure that our customers' data are protected effectively from any unwanted accessing.
Conference and interface
The snom 821 also offers a wide range of functions that are a necessity these days and highly valued particularly by our business customers. 5-way conferencing, multiple ringtones, and up to twelve different SIP identities are a few examples for the numerous business functionalities provided. The snom 821 allows our customers to operate completely indepently of their current environment - anytime, anyplace.
The phone user interface is designed to be operated intuitively. The keys are positioned so as to be easily seen and used from any angle, regardless of whether the snom 821 is set up with the footstand in the high or low position.
    With its large high-resolution TFT color display the snom 821 offers a brilliant depiction of call lists, phone directories, and caller information via the integrated XML browser.
  • Wideband technology
  • WLAN
snom 821 - VoIP phone - 5-way call capability
VoIP phone
Main Features
Integrated Ethernet switch
VoIP Protocols
SIP
Voice Codecs
G.722, G.723.1, G.729ab, G.711u, G.711a, G.726, iLBC
Speakerphone
Yes (digital duplex)
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
Automatic Redial
Missed Calls Memory
250
Display
LCD display - colour - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
Body Colour
VoIP phone
Body Colour
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
5-way
Speakerphone
Automatic Redial
Menu Operation
Function Buttons
Speakerphone button, transfer button, directory button, navigator key, headset button, mute button, hold button
Volume Control
Ringer Control
Indicators
Voice message waiting indicator, new call indicator
Firmware Upgradable
Additional Functions
Call timer, built-in clock, Web browser, automatic redial
Additional Features
Key lock, music on hold, built-in web server
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP
Voice Codecs
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
IP Address Assignment
DHCP, static
Power Over Ethernet (PoE) Support
Network Protocols
TCP, TFTP, UDP, HTTP
Network Ports Qty
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD)
Network Features
Network Address Translation (NAT)
Phone Memory
Phone Directory Capacity
1000 names & numbers
Missed Calls Memory
250
Dialed Calls Memory
250
Caller ID Memory
250 names & numbers
Display
Display Location
Base
Diagonal Size
3.5"
Display Resolution
320 x 240 pixels
Backlit
2 x headset jack , USB / 4 PIN USB Type A , USB / 4 PIN USB Type B
Network cable
Power adapter
FCC Class B certified
Power adapter - external
Dimensions & Weight (Base)
0.9 kg
Resources
The following resources are available for the snom 821 Black SIP IP Phone
