The basic model of the snom business telephone family, the snom 300, fulfils the most important requirements of VoIP telephony and additionally offers numerous functions that are indispensable in the business world.
For effective everyday work, the snom 300 provides all relevant office functions such as choice of trunk line, status display, group lines, the engaged option or picking up calls. A server-independent CTI now also works with the snom 300.
Main features
- Two-line display (2x16 characters)
- 27 keys, 7 LEDs
- 6 programmable function keys
- 2 Ethernet ports
- 4 SIP registrations ("lines")
- Headset connection
- SIP RFC3261
- Security: SIPS/SRTP, TLS
- STUN, ENUM, NAT, ICE
- Codecs: G.711, G.729A, G.723.1, G.722, G.726, GSM 6.10 (Full rate)
- Very low energy consumption
- Available colours: black
Display
A two-line LCD display enables the display of call information. The menu-driven user interface makes it very easy to manage numerous features. The user is guided intuitively through the phone menu via the navigation key. Additionally, more complex phone applications, call details, and configuration variations are accessible via the browser of the connected PC.
Functions
The snom 300 has six free function keys. The advantage for the user: He or she can freely decide what functions like hold, call transfer, call forward, or access mail box to map onto these keys. For other available functions please see the data sheet.
Environments
The snom 300 is designed for different environments: For use in small offices, call centers, lobbies, recreation rooms, as well as at home. With its numerous phone functions, the demands of everyday communication can be managed easily. The snom 300 has a headset connector and can be used as a tabletop phone or wall-mounted phone. Its energy consumption of 1.0-1.5 W/hr is lower than that of most competing products.
Codecs
As the snom 300 supports all of the common compression codecs such as G.729a and G.723.1, it is compatible with numerous components of other manufacturers and can be used in low-bandwidth environments. An integrated 2 Ethernet port switch enables connection to the network over an RJ-45 interface simultaneously with the PC connection!
- snom 300 - VoIP phone - 3-way call capability
- Product Type
- VoIP phone
- Main Features
- Integrated Ethernet switch
- VoIP Protocols
- SIP
- Voice Codecs
- G.722, G.723.1, G.729a, G.711u, G.711a, G.726, G.727
- Speakerphone
- Yes (digital duplex)
- Caller ID
- Call Services
- Caller ID, Call Waiting, Call Transfer, Call Hold, Message Waiting Capability
- Display
- LCD display - monochrome - Yes
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX
- Body Colour
- Black
- Product Type
- VoIP phone
- Body Colour
- Black
Phone Features
- Call Services
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- 3-way
- Speakerphone
- Menu Operation
- Function Buttons
- Speakerphone button, transfer button, directory button, navigator key, mute button, auto redial button
- Programmable Buttons Qty
- 6
- Volume Control
- Ringer Control
- Indicators
- Voice message waiting indicator
- Firmware Upgradable
- Additional Functions
- Call timer, built-in clock
- Additional Features
- Key lock, music on hold, built-in web server
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SIP
- Voice Codecs
- Quality of Service
- IEEE 802.1Q (VLAN)
- IP Address Assignment
- DHCP, static
- Power Over Ethernet (PoE) Support
- Network Protocols
- TCP, TFTP, UDP, HTTP
- Network Ports Qty
- Voice Features
- Comfort noise generation (CNG), voice activity detection (VAD)
- Network Features
- Network Address Translation (NAT)
Phone Memory
- Phone Directory Capacity
- 100 names & numbers
- Call Log Capacity
- 100 numbers
Display
- Display Location
- Base
- Line Qty
- 2
- Character Qty
- 16
- Backlit
- Connections
- Headset jack / RJ-11
- Included Accessories
- Power adapter
- FCC Class B certified, IEC 60950, CB
- Power adapter - external
Dimensions & Weight (Base)
- 20 cm
- 18.5 cm
- 12 cm
- 730 g
