Smart Technologies SPNL-4075 75" Interactive Flat Panel 10 Point Touch
Quicklinx: CNKNWS00 Mfr#: SPNL-4075
The accurate, natural, and responsive touch experience from corner to corner. Fingers glide effortlessly over the surface, providing hours of error-free use in perfect comfort. Writing is natural and looks better with SMART ink. Whether you're using a pen or finger, each stroke is a work of art. Its realistic digital ink improves legibility, so teachers don't have to re-write and students feel confident contributing.
  • Silktouch technology
  • SMART ink technology
  • Brilliant resolution
    Durable LED panels display images in 1080p resolution. No more downtime fixing burnt out projector bulbs, no shadows getting in the way, no glare or hot spots, and no faded images.
  • Simultaneous touch points
    With up to 10 simultaneous touch points, multiple students can use gestures, like zoom, rotate and flip, at the same time. The natural learning experience develops essential life-long collaboration skills without students realizing.
SMART Board 4075 75" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
75"
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
350 Watt
172.5 cm x 16.3 cm x 100.4 cm
86 kg
2 years warranty
350 Watt
Diagonal Class
75"
Combined with
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
172.5 cm
16.3 cm
100.4 cm
86 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Touchpoints Qty
10
Response Time
6 ms
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
1000 x 600 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
3 x HDMI input - bottom , Audio line-out - bottom , Audio line-in - bottom , USB 2.0 - bottom , USB 2.0 - bottom , Composite video/audio input - bottom , Component video input - bottom , VGA input - bottom , SPDIF output - bottom , HDMI input - side , USB 2.0 - side
2 touch pens, pen tray, SMART Notebook software
USB cable - 5 m , VGA cable - 1.8 m
UL, cUL, IC, FCC, RoHS, WEEE, REACH, RCM
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Width (Shipping)
184.2 cm
Depth (Shipping)
28 cm
Height (Shipping)
128.5 cm
Weight (Shipping)
110 kg
5 °C
35 °C
10 - 80% (non-condensing)
