The accurate, natural, and responsive touch experience from corner to corner. Fingers glide effortlessly over the surface, providing hours of error-free use in perfect comfort. Writing is natural and looks better with SMART ink. Whether you're using a pen or finger, each stroke is a work of art. Its realistic digital ink improves legibility, so teachers don't have to re-write and students feel confident contributing.
Silktouch technology
The accurate, natural, and responsive touch experience from corner to corner. Fingers glide effortlessly over the surface, providing hours of error-free use in perfect comfort. -
SMART ink technology
Writing is natural and looks better with SMART ink. Whether you're using a pen or finger, each stroke is a work of art. Its realistic digital ink improves legibility, so teachers don't have to re-write and students feel confident contributing. -
Brilliant resolution
Durable LED panels display images in 1080p resolution. No more downtime fixing burnt out projector bulbs, no shadows getting in the way, no glare or hot spots, and no faded images. -
Simultaneous touch points
With up to 10 simultaneous touch points, multiple students can use gestures, like zoom, rotate and flip, at the same time. The natural learning experience develops essential life-long collaboration skills without students realizing.
- SMART Board 4075 75" LED-backlit LCD display - 4K
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 75"
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, 2 touch pens, pen tray, SMART Notebook software
- Voltage
- AC 120/230 V (50/60 Hz)
- 350 Watt
- Power Consumption Stand by
- 0.5 Watt
- 172.5 cm x 16.3 cm x 100.4 cm
- 86 kg
- 2-year warranty
- Product Type
- 350 Watt
- Diagonal Class
- 75"
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- 172.5 cm
- 16.3 cm
- 100.4 cm
- 86 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 6 ms
- Infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 1000 x 600 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- 3 x HDMI input - bottom , Audio line-out - bottom , Audio line-in - bottom , USB 2.0 - bottom , USB 2.0 - bottom , Composite video/audio input - bottom , Component video input - bottom , VGA input - bottom , SPDIF output - bottom , HDMI input - side , USB 2.0 - side
- 2 touch pens, pen tray, SMART Notebook software
- Cables Included
- USB cable - 5 m , VGA cable - 1.8 m
- UL, cUL, IC, FCC, RoHS, WEEE, REACH, RCM
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Limited warranty - 2 years
- Width (Shipping)
- 184.2 cm
- Depth (Shipping)
- 28 cm
- Height (Shipping)
- 128.5 cm
- Weight (Shipping)
- 110 kg
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
