Smart Technologies SMS Flatscreen x stand
Quicklinx: 70B9WS00 Mfr#: PD031002-P0
This is a very flexible solution mounted on wheels that allows the screen to be rotated from a vertical to a horizontal position after mounting. The bracket is easy to add shelves and cabinets for DVDs and other peripherals.
SMS Flatscreen X FH M1455 stand - for flat panel - white, aluminium
Stand - floor-standing
88.3 cm x 69.1 cm x 162 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
40"-60"
VESA Mounting Interface
200 x 200 mm, 800 x 400 mm
Max Load Weight
50 kg
White, aluminium
5-year warranty
88.3 cm
69.1 cm
162 cm
White, aluminium
AV Furniture
Stand
Recommended Use
Flat panel
Placing / Mounting
Floor-standing
40"-60"
Adjustments
Tilt
Max Load Weight
50 kg
Wheels
Limited warranty - 5 years
