The SMART Board 6065 Pro interactive display with iQ is the hub of your meeting room. PC-free embedded computing provides one-touch access to collaborative tools, including a whiteboard, wireless screen sharing and a web browser. There's no need for wires, cables or manual software and firmware updates.
The 75" 4K ultra-high-definition LED display provides optimal image clarity and wide viewing angles. With the Pen ID feature, you can assign different appearances to the two pens and write or draw over any application in digital ink. Object Awareness allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser - all without switching tools or modes. You can use a variety of gestures in applications, and two users can write or draw at the same time.
Technology designed for collaborative, remote teams
Brainstorm on a whiteboard. Work on standard business applications. Host videoconferences. SMART makes sharing ideas with your colleagues around the world as natural as meeting over coffee. With SMART, you can pass ideas back and forth between mobile devices, PCs, and interactive displays as fast as you can think of them. SMART interactive displays, whiteboards, and video conferencing systems are global collaboration hubs where product ideas are born, big decisions are made, and businesses plot the future of entire industries. Every great idea began with a scribble on a whiteboard and conversation. SMART allows you to loop in more minds, insights and perspectives at once. We're changing the way collaboration happens in the mobile age.
- SMART Board 6065 Pro interactive display with iQ 65" LED-backlit LCD display - 4K - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen (multi touch)
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Bluetooth
- PC Interface
- DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- 4 ports
- Included Accessories
- 2 touch pens, SMART Meeting Pro software (room licence), iQ appliance, SMART Meeting Pro software (10 personal licences)
- Voltage
- AC 120/230 V (50/60 Hz)
- 189 Watt
- Power Consumption Stand by
- 2.2 Watt
- 150.8 cm x 12 cm x 97.8 cm
- 60.9 kg
- 3-year warranty
- Product Type
- 189 Watt
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen (multi touch)
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Presence sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DisplayPort
- 150.8 cm
- 12 cm
- 97.8 cm
- 60.9 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 1200:1
- Brightness
- 338 cd/m²
- Viewing Angle
- 178 degrees
- Touchpoints Qty
- 8
- Response Time
- 8 ms
- Digital Vision Touch technology
Stands & Mounts
- Flat Panel Mount Interface
- 300 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 4
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- Bluetooth
- Connector Type
- 2 x HDMI input - side , 3 x USB 2.0 - side , Audio line-out - side , DisplayPort - side , Serial - side , USB 2.0 - bottom
- Cables Included
- USB cable - 5 m
- UL, CCC, IC, FCC, RoHS, WEEE, PSE Mark, REACH, KC, EAC, RCM, SPRING
- Power Device
- Power supply
- Input Voltage
- 2.2 Watt
- Limited warranty - 3 years
- Width (Shipping)
- 175.8 cm
- Depth (Shipping)
- 30.3 cm
- Height (Shipping)
- 126.1 cm
- Weight (Shipping)
- 82.1 kg
- 5 °C
- 35 °C
- 5 - 80% (non-condensing)
