Smart Technologies SMASPNL6265P and Meeting Pro bundle
Quicklinx: D5KWWS00 Mfr#: SPNL-6265P
The SMART Board 6065 Pro interactive display with iQ is the hub of your meeting room. PC-free embedded computing provides one-touch access to collaborative tools, including a whiteboard, wireless screen sharing and a web browser. There's no need for wires, cables or manual software and firmware updates.
The 75" 4K ultra-high-definition LED display provides optimal image clarity and wide viewing angles. With the Pen ID feature, you can assign different appearances to the two pens and write or draw over any application in digital ink. Object Awareness allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser - all without switching tools or modes. You can use a variety of gestures in applications, and two users can write or draw at the same time.
Technology designed for collaborative, remote teams
Brainstorm on a whiteboard. Work on standard business applications. Host videoconferences. SMART makes sharing ideas with your colleagues around the world as natural as meeting over coffee. With SMART, you can pass ideas back and forth between mobile devices, PCs, and interactive displays as fast as you can think of them. SMART interactive displays, whiteboards, and video conferencing systems are global collaboration hubs where product ideas are born, big decisions are made, and businesses plot the future of entire industries. Every great idea began with a scribble on a whiteboard and conversation. SMART allows you to loop in more minds, insights and perspectives at once. We're changing the way collaboration happens in the mobile age.
SMART Board 6065 Pro interactive display with iQ 65" LED-backlit LCD display - 4K - for interactive communication
LED-backlit LCD flat panel display with touchscreen (multi touch)
Diagonal Class
65"
Commercial Use
Yes - interactive
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
Bluetooth
PC Interface
DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
4 ports
2 touch pens, SMART Meeting Pro software (room licence), iQ appliance, SMART Meeting Pro software (10 personal licences)
Voltage
189 Watt
Power Consumption Stand by
2.2 Watt
150.8 cm x 12 cm x 97.8 cm
60.9 kg
3-year warranty
189 Watt
Diagonal Class
65"
Commercial Use
Yes - interactive
Combined With
Touchscreen (multi touch)
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Presence sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DisplayPort
150.8 cm
12 cm
97.8 cm
60.9 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1200:1
Brightness
338 cd/m²
Viewing Angle
178 degrees
Touchpoints Qty
8
Response Time
8 ms
Digital Vision Touch technology
Stands & Mounts
Flat Panel Mount Interface
300 x 400 mm
Media Player
USB Port
USB Ports Qty
4
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Bluetooth
Connector Type
2 x HDMI input - side , 3 x USB 2.0 - side , Audio line-out - side , DisplayPort - side , Serial - side , USB 2.0 - bottom
USB cable - 5 m
UL, CCC, IC, FCC, RoHS, WEEE, PSE Mark, REACH, KC, EAC, RCM, SPRING
Power supply
Input Voltage
2.2 Watt
Limited warranty - 3 years
Width (Shipping)
175.8 cm
Depth (Shipping)
30.3 cm
Height (Shipping)
126.1 cm
Weight (Shipping)
82.1 kg
5 °C
35 °C
5 - 80% (non-condensing)
