Smart Technologies SMART Board Interactive Whiteboard 480 - Whiteboard - 156.5 x 117.3 cm - Education
Quicklinx: 7SFPWS00 Mfr#: SB480
The hard-coated steel surface is durable, optimized for projection, compatible with dry-erase markers and easily cleaned with whiteboard cleaner or isopropyl alcohol (IPA).
Dimensions & Weight / Depth
12.8 cm
Dimensions & Weight / Height
127.2 cm
Dimensions & Weight / Weight
23.2 kg
Dimensions & Weight / Width
160.5 cm
Header / Product Line
SMART Board
Input Device / Movement Detection Technology
Digital vision touch
7SFP Smart Technologies SMART Replacement Nibs - SB480/SBX8 (4) In Stock £8.18
Resources
The following resources are available for the Smart Technologies SMART Board Interactive Whiteboard 480 - Whiteboard - 156.5 x 117.3 cm - Education
