The SMART Board 7075 interactive display with iQ is the hub of your classroom. iQ technology connects devices, lesson content and pedagogically relevant software to create a cohesive educational experience. PC-free embedded computing provides one-touch access to a diverse suite of SMART applications—Notebook lessons, amp workspaces, lab gamification activities and whiteboard—and collaborative tools, such as wireless screen sharing and a web browser. There’s no need for wires, cables or manual software and firmware updates.
The 75" 4K ultra-high-definition LED display provides optimal image clarity and wide viewing angles. With the Pen ID feature, you can assign different appearances to the four pens and write or draw over any application in digital ink.
Object Awareness allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser—all without switching tools or modes. You can use a variety of gestures in applications, and four users can write or draw at the same time.
- SMART Board 7075 with iQ and Intel Compute Card 7000 Series - 75" LED-backlit LCD display - 4K - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen (multi touch)
- Diagonal Class
- 75"
- Commercial Use
- Yes - interactive
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- PC Interface
- VGA (HD-15), DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- 72% Colour Gamut
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Eraser, 4 pen styluses, iQ appliance, Intel Compute Card
- Voltage
- AC 120/230 V (50/60 Hz)
- 150 Watt
- Power Consumption Stand by
- 17 Watt
- 175.4 cm x 12.4 cm x 109.5 cm
- 79 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- 150 Watt
- Diagonal Class
- 75"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen (multi touch)
- Series
- 7000 Series
- Operating System
- Windows 10
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- 72% Colour Gamut
- 175.4 cm
- 12.4 cm
- 109.5 cm
- 79 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 5000:1
- Brightness
- 360 cd/m²
- Viewing Angle
- 178 degrees
- Touchpoints Qty
- 16
- Response Time
- 8 ms
- Display Menu Language
- Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Norwegian, Swedish, Russian, Spanish, Japanese, Korean
- Pen ID, Object Awareness, presence detection, HyPr Touch (Hybrid Precision Touch) technology
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- Configuration
- Intel Core i5-7Y57
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi Protocol
- 802.11b, 802.11g, 802.11n, 802.11a, 802.11ac
- Bluetooth Version
- Bluetooth 4.0
- Connector Type
- 2 x HDMI input , VGA input , Audio line-out , SPDIF output , Audio line-in , USB , 3 x USB , RS-232 input , DisplayPort input , RS-232 output , 2 x LAN
- Cables Included
- USB cable
- UL, cUL, FCC, RoHS, WEEE, REACH, RCM, TRA, HDCP 2.2, HDCP 1.4, ISED, LV, RED, CITIC, CONEG
Sustainability Information
- ENERGY STAR Certified
- Power Device
- Power supply
- Input Voltage
- 17 Watt
- Limited warranty - 3 years
- Width (Shipping)
- 191.6 cm
- Depth (Shipping)
- 30 cm
- Height (Shipping)
- 137.8 cm
- Weight (Shipping)
- 103 kg
- 5 °C
- 35 °C
- 5 - 80% (non-condensing)
