Do more, experience more, grow more. More space, with larger screen sizes. More style, with a new design. More options, with new USB speakers and an expansion slot.
Inspired by feedback from the customers, the new SMART Board 600 series interactive whiteboard lets you do more than ever before. Combining the same great features that people love with new expandability options, it's limited only by your imagination.
- SMART Board Interactive Whiteboard 640 - touchscreen - USB
- Touchscreen
- Connectivity Technology
- Wired - USB
- 106.7 cm x 13 cm x 81.3 cm
- 6.7 kg
- Movement Detection Technology
- Resistive
- Cables Included
- 1 x USB cable - external - 4.9 m
- 5-year warranty
- Touchscreen
- 106.7 cm
- 13 cm
- 81.3 cm
- 6.7 kg
Input Device
- Wired
- Interface
- USB
- Resistive
- Active Area
- 97.5 cm x 73 cm
- 1 x USB - 4 pin USB Type A
- Included Accessories
- SMART Pen Tray, eraser, wallmount brackets, styluses (4 pcs)
- Cables Included
- CSA, TUV, CB
- Software Included
- SMART Board
- Limited warranty - 5 years
- 5 °C
- 35 °C
- 0 - 80%
