Smart Technologies SMART Board 6065 Interactive Flat Panel 3 Year Advantage
Quicklinx: BDS7WS00 Mfr#: SPNL-6065
Responsive touch functionality by SMART is more natural and seamless than ever before, and low-friction coated surface that stays cool to the touch. With multi-touch interactivity, multiple students can work together or independently at the panel with fingers or a pen. The 6065 recognizes multiple pen users, so two users can write and draw in different colored digital ink, simultaneously. Your color, your call.
  • Premium touch experience
    Responsive touch functionality by SMART that's more natural and seamless than ever before, and low-friction coated surface that stays cool to the touch.
  • Intuitive at every touch
    Go from pen to fingers to palm of your hand with object awareness. Flick, rotate, zoom, erase using natural touch gestures that are intuitive and easy to use.
  • Multi-touch collaboration
  • Think in ink
SMART Board 6065 65" LED-backlit LCD display - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Commercial Use
Yes - interactive
Resolution
3840 x 2160
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Eraser, 2 touch pens, pen tray, SMART Notebook software
Voltage
190 Watt
Power Consumption Stand by
38 Watt
150.8 cm x 12 cm x 97.8 cm
61.4 kg
190 Watt
Diagonal Class
65"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
150.8 cm
12 cm
97.8 cm
61.4 kg
Display
Resolution
3840 x 2160
Image Aspect Ratio
16:9
LED backlight
Pixel Pitch
0.372mm
Touchpoints Qty
4
Optical Touch technology
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
HDMI input , USB 2.0 , Audio line-out
USB cable - 5 m
UL, C-Tick, CB, IC, PSB, FCC, RoHS, WEEE, REACH
Input Voltage
38 Watt
Width (Shipping)
175.8 cm
Depth (Shipping)
30.3 cm
Height (Shipping)
126.1 cm
Weight (Shipping)
81.1 kg
5 °C
35 °C
5 - 80% (non-condensing)
