The SMART Podium 624 Pro interactive pen display enables a presenter to face an audience while mirroring a connected computer's display to a large format display. The podium includes SMART Meeting Pro software and facilitates interactivity in business boardrooms and auditoriums. The SMART Podium 624 Pro works with your computer and SMART Product Drivers to provide a reliable interactive experience. You can do everything you do at your computer - use SMART Ink, open and close applications, create and edit documents, visit websites, play and manipulate videos and more - just by touching the podium's surface with your finger. Use the pen for precise annotation over presented materials, and you can save your notes in many applications. In addition to the familiar features of other SMART podiums, the HDCP-compliant SMART Podium 624 Pro includes easily accessible buttons, a pen rest, and a stand.
- SMART Podium 624 Pro - touchscreen - USB, DVI-I
- Touchscreen
- Connectivity Technology
- Wired - USB, DVI-I
- Display
- LCD display - 24" - 1920 x 1080
- 60 cm x 4.6 cm x 35.6 cm
- 7.2 kg
- Multi-Touch
- Movement Detection Technology
- Electromagnetic / capacitive
- Pressure sensitive pen, -/+ 60 levels tilt recognition, battery-free stylus, security lock slot, 60° vertical
- Power
- AC 120/230 V
- OS Required
- Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.11, Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13
- 3-year warranty
- Touchscreen
- 60 cm
- 4.6 cm
- 35.6 cm
- 7.2 kg
Input Device
- Wired
- Interface
- USB, DVI-I
- Multi-Touch
- Pressure Levels
- 2048
- Active Area
- 52.7 cm x 29.7 cm
Display
- LCD display
- Diagonal Size
- 24"
- Image Aspect Ratio
- 16:9
- Colour Support
- 16.7 million colours
- Native Resolution
- 1920 x 1080
- Image Brightness
- 210 cd/m²
- Image Contrast Ratio
- 1000:1
- Vertical Refresh Rate
- 60 Hz
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +75 / -75
- Response Time
- 32 ms
- 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x video - DVI-Analogue/Digital (dual link) input - DVI-I , 1 x video - DVI-Analogue/Digital (dual link) output - DVI-I
- Included Accessories
- Nibs (5 pcs.), stand, nib removal tool, electronic pen, pen tray, stylus tether, pen holder, DVI-D to HDMI cable adapter (2m), VGA to DVI-A cable (2m), USB cable (Type-A to Type-B) (2m), DVI-D to DVI-D cable (2m)
- FCC, RoHS, WEEE, REACH, RCM, HDCP 1.4, ISED, CONEG
- Voltage Required
- AC 120/230 V
- Power Consumption
- 40 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- SMART Meeting Pro
- OS Required
- Shipping Width
- 70 cm
- Shipping Depth
- 24 cm
- Shipping Height
- 55 cm
- Shipping Weight
- 11.2 kg
- Limited warranty - 3 years , Limited warranty - digital pen - 1 year
- 5 °C
- 35 °C
- 30 - 80% (non-condensing)
