Chief upgraded fixed wall mounts based on installer feedback and direct observations of installers in the field. Many features join Fusion favorites like Centerless shift, ControlZone leveling adjustment and ClickConnect latching.
The benefits included added stability, faster install, improved lateral shift, easier cable management and enhanced security.
Installer-inspired Fusion fixed mount solves top flat panel installation problems, offering flexible adjustments for large displays with a low-profile display mounting solution.
- Chief Fusion Large Adjustable Fixed Display Wall Mount - For Displays 42-86" - Black mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Mounting Components
- Wall mount
- 88.3 cm x 5.1 cm x 46.4 cm
- Recommended Use
- Flat panel
- Recommended Display Size
- 42"-86"
- Max Mounting Pattern Size
- 871 x 400 mm
- Max Load Weight
- 91 kg
- Mounting Stud Centers
- 32", 16"
- Black
- 88.3 cm
- 5.1 cm
- 46.4 cm
- Black
AV Furniture
- Mounting kit
- Wall mount
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 871 x 400 mm
- 32", 16"
- 42"-86"
- Max Load Weight
- 91 kg
- Fixed, lateral shift, ClickConnect Technology, Controlzone Leveling, Centreless Shift, Centris Low-Profile Tilt
