Your SMART Board M600 series interactive whiteboard is durable and reliable. It features a rugged, hardened interactive surface, two damage-resistant pens and SMART's proprietary DViT (Digital Vision Touch) technology.
DViT technology
Four digital cameras, one in each of the interactive whiteboard's corners, track the position of your finger or the pen as it moves across the interactive surface. -
Multitouch gestures
Your interactive whiteboard supports multitouch gestures. You can use two fingers to resize an object on a page, to rotate an object, to zoom in and out and more. -
Dual touch and dual write
Your interactive whiteboard supports dual touch. Two users can use their fingers to simultaneously perform mouse functions or write on the interactive whiteboard. -
Durable surface
The interactive surface is scratch-resistant, dent-resistant and optimized for projection.
- SMART Board Interactive Whiteboard M680 - interactive whiteboard - USB - white, light grey
- Interactive whiteboard
- Connectivity Technology
- Wired - USB
- White, light grey
- 166 cm x 15.3 cm x 131.2 cm
- Movement Detection Technology
- Digital vision touch
- Steel frame
- Cables Included
- 1 x USB cable - external - 5 m
- OS Required
- Apple MacOS, Microsoft Windows
- 2-year warranty
- 166 cm
- 15.3 cm
- 131.2 cm
- White, light grey
Input Device
- Wired
- Interface
- USB
- Active Area
- 156.5 cm x 117.5 cm
- Steel frame
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Pen tray, styluses (2 pcs)
- Cables Included
- CSA, RoHS, WEEE, REACH, ERP
- Software Included
- SMART Notebook
- OS Required
- Limited warranty - whiteboard - 2 years
- 5 °C
- 35 °C
- 0 - 80% (non-condensing)
