Experience an extraordinarily natural way to interact with lessons with the SMART Board 800 series interactive whiteboard. It enables two users to start working on lesson activities simultaneously, using their fingers or a pen. With the 800 series, teachers and students can truly collaborate, making lessons more magical and interactive.
The 800 series represents a class of interactive whiteboard. As a powerful, multi-touch interactive whiteboard, the 800 series enables two users to simultaneously interact on the system's surface, while using different tools or their fingers to write, draw and manipulate lesson content. The interactive whiteboard doesn't have restricted user areas or a separate multi-user mode, so collaborative opportunities are always at your fingertips.
Use simple, intuitive hand and finger gestures to interact with your lesson content. The touch gesture capabilities of the 800 series make it easy for you to toss, rotate or zoom in on lesson content, or control applications.
Hands-on collaboration
The 800 series represents a class of interactive whiteboard. As a powerful, multi-touch interactive whiteboard, the 800 series enables two users to simultaneously interact on the system's surface, while using different tools or their fingers to write, draw and manipulate lesson content. -
The magic of touch
Use simple, intuitive hand and finger gestures to interact with your lesson content. The touch gesture capabilities of the 800 series make it easy for you to toss, rotate or zoom in on lesson content, or control applications. -
Multi-touch experience
Two users can simultaneously write, perform mouse functions, erase, and manipulate and move objects on the interactive whiteboard surface - and no special tools are required. -
Freestyle interaction
The system enables two users to instantly start working together without having to switch into a separate multi-user mode or work in a confined area. And each user can individually complete actions, like writing in digital ink or moving objects with their fingers. -
Object awareness
The 800 series recognizes when a user switches between using a finger, pen and eraser. A user can also write with a pen, erase with a palm and move objects with a finger, without having to press buttons, access on-screen menus or replace tools in the pen tray. -
Durable surface
The 800 series has a low-gloss surface that is optimized for projection. The surface is compatible with dry-erase markers and magnets and is easily cleaned.
