The SMARTBoard 6075 interactive flat panel with iQ is the hub of your classroom. iQ technology connects devices, lesson content and pedagogically relevant software to create a cohesive educational experience. PC-free embedded computing provides one-touch access to a diverse suite of SMART applications - Notebook lessons, amp workspaces, lab gamification activities and whiteboard - and collaborative tools, such as wireless screen sharing and a web browser. There's no need for wires, cables or manual software and firmware updates. The 75" 4K ultra-high-definition LED display provides optimal image clarity and wide viewing angles. With the PenID feature, you can assign different appearances to the two pens and write or draw over any application in digital ink. Object Awareness allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser - all without switching tools or modes. You can use a variety of gestures in applications, and two users can write or draw at the same time
Silktouch technology
The most accurate, natural, and responsive touch experience from corner to corner. Fingers glide effortlessly over the surface, providing hours of error-free use in perfect comfort. -
Pen ID
Students can see their contributions free from interruption by their partner. Using different colored ink, you can write independently and simultaneously in any lesson activity to open new collaborative opportunities. -
Object awareness
You already know how to use it. Offering the most intuitive experience by automatically differentiating between a finger, pen or palm, do what comes naturally. Touch, write, erase. Simplicity at its finest. -
SMART ink technology
Writing is natural and looks better with SMART ink. Whether you're using a pen or finger, each stroke is a work of art. Its realistic digital ink improves legibility, so teachers don't have to re-write and students feel confident contributing. -
4K Ultra HD resolution
Durable commercial-grade, glare-free LED panels display brilliantly detailed 4K Ultra HD images and text (3840 x 2160 pixels). Crisp content clarity and readability keeps students involved no matter where they're seated in the room. No more downtime fixing burnt out projector bulbs, no shadows getting in the way, no glare or hot spots, and no faded images. -
Simultaneous touch points
With 4 simultaneous touch points, two students can use gestures, like zoom, rotate and flip, at the same time. The natural learning experience develops essential life-long collaboration skills without students realizing it.
- SMART Board 6075 75" LED display
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 75"
- Commercial Use
- Yes - interactive
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Bluetooth
- PC Interface
- DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- 4 ports
- Voltage
- AC 120/230 V (50/60 Hz)
- 131 Watt
- Power Consumption Stand by
- 2 Watt
- 173.1 cm x 12 cm x 110.2 cm
- 84 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- 131 Watt
- Diagonal Class
- 75"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Presence sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- DisplayPort
- 173.1 cm
- 12 cm
- 110.2 cm
- 84 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 5000:1
- Brightness
- 360 cd/m²
- Viewing Angle
- 178 degrees
- Touchpoints Qty
- 8
- Response Time
- 8 ms
- 72% Color Gamut NTSC, Digital Vision Touch technology, Pen ID, Object Awareness
Stands & Mounts
- VESA Mounting Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 4
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
- Connectivity
- Bluetooth
- Connector Type
- 2 x HDMI input - side , 3 x USB 2.0 - side , Audio line-out - side , DisplayPort - side , Serial - side , USB 2.0 - bottom
- Included Accessories
- 2 touch pens, iQ appliance, SMART Learning Suite
- Cables Included
- USB cable - 5 m
- UL, VCCI, EMC, IC, FCC, RoHS, WEEE, PSE Mark, REACH, KC, LV
- ENERGY STAR Certified
- Power Device
- Power supply
- Nominal Voltage
- 2 Watt
- Limited warranty - 3 years
- Width (Shipping)
- 191.6 cm
- Depth (Shipping)
- 35.5 cm
- Height (Shipping)
- 138 cm
- Weight (Shipping)
- 108 kg
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
