Smart Technologies 75" Interactive Flat Panel 4 Touch Points 16:9 3 Years Warranty
Quicklinx: CVJPWS00 Mfr#: SPNL-6275
The SMARTBoard 6075 interactive flat panel with iQ is the hub of your classroom. iQ technology connects devices, lesson content and pedagogically relevant software to create a cohesive educational experience. PC-free embedded computing provides one-touch access to a diverse suite of SMART applications - Notebook lessons, amp workspaces, lab gamification activities and whiteboard - and collaborative tools, such as wireless screen sharing and a web browser. There's no need for wires, cables or manual software and firmware updates. The 75" 4K ultra-high-definition LED display provides optimal image clarity and wide viewing angles. With the PenID feature, you can assign different appearances to the two pens and write or draw over any application in digital ink. Object Awareness allows you to perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser - all without switching tools or modes. You can use a variety of gestures in applications, and two users can write or draw at the same time
  • Silktouch technology
    The most accurate, natural, and responsive touch experience from corner to corner. Fingers glide effortlessly over the surface, providing hours of error-free use in perfect comfort.
  • Pen ID
    Students can see their contributions free from interruption by their partner. Using different colored ink, you can write independently and simultaneously in any lesson activity to open new collaborative opportunities.
  • Object awareness
    You already know how to use it. Offering the most intuitive experience by automatically differentiating between a finger, pen or palm, do what comes naturally. Touch, write, erase. Simplicity at its finest.
  • SMART ink technology
    Writing is natural and looks better with SMART ink. Whether you're using a pen or finger, each stroke is a work of art. Its realistic digital ink improves legibility, so teachers don't have to re-write and students feel confident contributing.
  • 4K Ultra HD resolution
    Durable commercial-grade, glare-free LED panels display brilliantly detailed 4K Ultra HD images and text (3840 x 2160 pixels). Crisp content clarity and readability keeps students involved no matter where they're seated in the room. No more downtime fixing burnt out projector bulbs, no shadows getting in the way, no glare or hot spots, and no faded images.
  • Simultaneous touch points
    With 4 simultaneous touch points, two students can use gestures, like zoom, rotate and flip, at the same time. The natural learning experience develops essential life-long collaboration skills without students realizing it.
SMART Board 6075 75" LED-backlit LCD display - 4K - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
75"
Commercial Use
Yes - interactive
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
Bluetooth
PC Interface
DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
72% Colour Gamut
Speaker System
2 speakers
USB
4 ports
2 touch pens, iQ appliance, SMART Learning Suite
Voltage
131 watt
Power Consumption Stand by
2 watt
173.1 cm x 12 cm x 110.2 cm
84 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
131 watt
Diagonal Class
75"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Presence sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DisplayPort
72% Colour Gamut
173.1 cm
12 cm
110.2 cm
84 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
5000:1
Brightness
360 cd/m²
Viewing Angle
178 degrees
Touchpoints Qty
8
Response Time
8 ms
Digital Vision Touch technology, Pen ID, Object Awareness
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Media Player
USB Port
USB Ports Qty
4
Audio System
Speaker System
2 speakers
Output Power / Total
20 watt
Speakers
2 x main channel speaker - 10 watt
Network & Internet Multimedia
Bluetooth
Connector Type
2 x HDMI input - side , 3 x USB 2.0 - side , Audio line-out - side , DisplayPort - side , Serial - side , USB 2.0 - bottom
USB cable - 5 m
UL, VCCI, EMC, IC, FCC, RoHS, WEEE, PSE Mark, REACH, KC, LV
Sustainability Information
ENERGY STAR Certified
Power supply
Input Voltage
2 watt
Limited warranty - 3 years
Width (Shipping)
191.6 cm
Depth (Shipping)
35.5 cm
Height (Shipping)
138 cm
Weight (Shipping)
108 kg
5 °C
35 °C
10 - 80% (non-condensing)
Resources
The following resources are available for the Smart Technologies 75" Interactive Flat Panel 4 Touch Points 16:9 3 Years Warranty
