The SMART Board 7086 interactive display combines a premium touch experience. The LED display provides optimal image clarity and wide viewing angles.
- SMART Board 7086 interactive display with iQ and Intel Compute Card (M3) 86" LED-backlit LCD display - 4K - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 86"
- Commercial Use
- Yes - interactive
- White
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN, Bluetooth
- PC Interface
- VGA (HD-15), DisplayPort
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Internet Streaming Services
- Google Cast
- Picture Enhancements
- 72% Color Gamut (CIE 1931)
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Eraser, 4 pen styluses
- Voltage
- AC 120/230 V (50/60 Hz)
- 280 Watt
- Power Consumption Stand by
- 2 Watt
- 200.1 cm x 14.2 cm x 123.5 cm
- 91 kg
- 3-year warranty
- Product Type
- 280 Watt
- Diagonal Class
- 86"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- 200.1 cm
- 14.2 cm
- 123.5 cm
- 91 kg
- Enclosure Colour
- White
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 5000:1
- Brightness
- 360 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 10
- Response Time
- 8 ms
- HyPr Touch (Hybrid Precision Touch) technology
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN, Bluetooth
- LAN Protocol
- Fast Ethernet
- Connect & Share
- Wi-Fi Miracast
- Google Cast
- Connector Type
- USB 2.0 - side , USB 2.0 - side , 2 x HDMI input - rear , 4 x USB 2.0 - rear , 2 x HDMI output - rear , DisplayPort - rear , VGA input - rear , 3 x USB 2.0 , Digital audio input/output (optical) - rear , Audio line-in - rear , Audio line-out - rear , LAN - rear , Serial input - rear , Serial output - rear
- UL, cUL, FCC, RoHS, WEEE, REACH, RCM, TRA, HDCP 2.2, HDCP 1.4, ISED, CITIC, CONEG
- Power Device
- Power supply
- Input Voltage
- 2 Watt
- Limited warranty - 3 years
- Width (Shipping)
- 220 cm
- Depth (Shipping)
- 35.5 cm
- Height (Shipping)
- 163 cm
- Weight (Shipping)
- 117 kg
- 5 °C
- 35 °C
- 5 - 80% (non-condensing)
