The 70-300mm F4-5.6 DG MACRO for Nikon is a telephoto zoom lens with excellent value for money and optimized for use with digital SLR cameras. This telephoto lens has a 1:2 maximum magnification at the 300mm focal length. It is ideal for portraits, sport and other types of photography. SLD (Special Low Dispersion) glass provides excellent correction of chromatic aberration. The super multi-layer coating reduces flare and ghosting. High image quality is assured throughout the entire zoom range.
- Sigma telephoto zoom lens - 70 mm - 300 mm
- Lens System
- Telephoto zoom lens
- Intended For
- Digital SLR, full-frame digital SLR
- Mounting Type
- Nikon F
- Lens Aperture
- F/4.0-5.6
- Focal Length
- 70 mm - 300 mm
- Optical Zoom
- 4.3 x
- Min Focus Distance
- 95 cm
- Focus Adjustment
- Automatic, manual
- Lens Construction
- 10 groups / 14 elements
- Special Functions
- Macro, tele, zoom
- Filter Size
- 58 mm
- Length
- 12 cm
- 0.55 kg
- Length
- 12 cm
- Diameter
- 7.7 cm
- 0.55 kg
Lens System
- Special Functions
- Macro, tele, zoom
- Intended For
- Focal Length
- 70 mm - 300 mm
- Lens Aperture
- F/4.0-5.6
- Minimum Aperture
- F/22
- Optical Zoom
- 4.3 x
- Magnification
- 1 / 2
- 95 cm
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Manual
- Max View Angle
- 34.3 degree(s)
- Min View Angle
- 8.2 degree(s)
- Lens Construction
- Filter Size
- 58 mm
- Diaphragm Blades
- 9
- Lens Coating
- Multicoated
- Mounting Type
- Nikon F
- SLD (Special Low Dispersion) glass
- Included Accessories
- Dust cap, lens cap
