Shuttle launches the entry-level cube PC-SH110R4 with impressive performance for diverse applications. The SH110R4 supports dual-screen displays via HDMI, DisplayPort, or VGA port and is compatible with Mini-ITX form factor mainboard. In a mere 13-liter barebones, the machine features highly expandable with PCI-E x16 slot and PCI-E x4, allowing for installation of dual slot graphics cards, video surveillance cards, and more. Equipped with Shuttle's I.C.E 2 cooling engine as well as 80 Plus Bronze certified with a 300W power supply, the SH110R4 is highly energy-efficient and stable for home, office, or even gaming.
Integrated Cooling Engine 2 (I.C.E.2) heat pipe technology
The XPC cube features stable, cool, and silent operation with Shuttle's I. C. E. 2 heat pipe technology. It uses convection cooling to dissipate heat away from and around the CPU. The I. C. E. 2 copper tubes, coated in nickel for enhanced tube hardness and rust-proof protection, are filled with distilled water to effectively channel heat and provide highly efficient processor and chassis cooling. -
Support PCI-E expansion cards
The SH110R4 provides one PCI-E x16 and one PCI-E x1 slots to meet various needs of users. Select the card you want to use, such as multi-display graphic cards, monitor cards, RAID cards, and professional sound cards, etc. -
Dual-screen display outputs
The SH110R4 features DisplayPort, HDMI, and VGA outputs to support dual-screen displays. Use an adaptor to convert HDMI into DVI interface and DisplayPort into HDMI or DVI interface for diversified signal selection, providing the option for dual monitors or standalone display. -
Support power-on by RTC
Enter Bios to set-up power on by RTC function can set system automatic power on. With Windows task scheduler, the system can power off automatically to achieve the goal of saving energy and operation cost. -
Support Mini-ITX motherboard
For various market demands, Shuttle expands its capabilities by adding support for Mini-ITX mainboards. The Shuttle chassis goes beyond the Shuttle mainboard, so you can easily upgrade to the mainboard of your desire without any modifications to the chassis. -
Customizable front panel
The front of R4 chassis is easily customized by simply changing the acrylic front plate. Add any design, such as a photo, graphic, or a company logo to the front panel. -
Equipped with an Intel 100 series Chipset
With new LGA 1151 socket, the SH110R4 is equipped with an Intel H110 Chipset and supports dual-channel DDR4 2133 memory with maximum memory capacity of up to 32GB. The device supports Intel Gigabit LAN, SATA 6Gbps, and USB3.0 high-speed storage interfaces, providing superb data transfer speed. -
Support 4K Ultra HD
The SH110R4 provides DisplayPort and HDMI video outputs to support 4K high resolution (3840x2160). Now with four times the resolution of Full HD, viewers can enjoy the super detailed and crystal clear imaging of 4K.
- Shuttle XPC cube SH110R4 - mini PC no CPU - 0 GB - no HDD
- PC barebone - mini PC
- Processor
- No CPU
- Processor Socket
- LGA1151 Socket
- RAM
- 0 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- No graphics
- Audio Output
- 5.1 channel surround
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- No operating system
- Software Included
- Drivers & Utilities
- Black
- 21.5 cm x 32.5 cm x 19.8 cm
- 3.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- PC barebone
- Product Form Factor
- Mini PC
- Black
Processor / Chipset
- CPU
- No CPU
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture
Hard Drive
- No HDD
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
- Max Allocated RAM Size
- 1760 MB
Audio Output
- Sound Output Mode
- High Definition Audio
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 1 (free) x external 5.25" , 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 1 (free) x internal M.2 2280 , 1 (total) / 1 (free) x internal M.2 2230
- Slots
- 1 (total) / 1 (free) x CPU , 2 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 2.0 x1
- 2 x microphone - mini-jack (1 front, 1 rear) , 1 x headphones - mini-jack (1 in front) , 4 x USB 3.0 (2 front, 2 rear) , 4 x USB 2.0 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x HDMI , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x PS/2 keyboard / mouse
- Cables Included
- Serial ATA cable (2 pcs.)
- C-Tick, BSMI, FCC, RoHS, ETL, Energy-using Products (EuP) Lot 6, EMI, Directive 73/23/EWG, Directive 89/336/EWG
- Power supply
- Voltage Required
- Power Provided
- 300 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
- Efficiency
- 82% at 20% Load, 85% at 50% Load, 82% at 100% Load
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 5.0
- 21.5 cm
- 32.5 cm
- 19.8 cm
- 3.4 kg
- 0 °C
- 35 °C
- 10 - 90%
