The Shuttle XH97V, with its Intel H97 Chipset and 4th and 5th generation of Intel Core processor support, delivers power and performance needed in the most demanding work environment. The 3.5 Liter chassis enables a balanced platform for creating a solution that's as powerful - or energy-efficient - as you want it to be to your office and business. The XH97V adds a new dimension to your video experience with built-in features included in 4th and 5th generation of Intel processors as well as new built-in 3D visuals, graphics, 4K ultra HD, and Intel WiDi which allows users to view content on an Intel WiDi-enabled TV Screen. The XH97V is specially designed to be business friendly with increased manageability and security. It supports Intel Small Business Advantage (Intel SBA) that allows users to monitor and maintain PC security, and helps prevent theft by blocking unwanted USB devices from being recognized on your PC. The XH97V also supports Intel Device Protection Technology with Boot Guard that helps block viruses and other malicious software from infecting your PC. With these security features in place, you can have a peace of mind knowing that your data is well-protected.
Supports Intel 4th generation Core processors
Featuring increased processing and graphics performance with support for Intel Haswell/Haswell Refresh 65W processors that integrate Intel HD Graphics series core and DirectX 11.1. -
Supports an Optical Disk Drive (slim ODD)
Perfect for home theatre or other environments where a Blu-ray disk drive is needed, the XH97V integrates an ODD bay. -
Supports 4K Ultra HD
HDMI and DisplayPort video outputs support 4K high resolution (3840x2160). Now with four times the resolution of Full HD, viewers can enjoy the crystal clear imaging of 4K. -
24/7 Certified
Approved for 24/7 operation, the system uses smart fan and heat-pipe technology to keep things cool for extended periods of operation. -
Watchdog Security Protection
Watchdog Timer provides excellent security protection for systems that need to operate continuously for long periods of time. If a problem occurs, the system will quickly recover normal operating status for seamless security protection. -
Add extra storage or an ODD
Users can install additional storage and/or a slim line ODD with the following configurations: A) Two 2.5” storage drives and a slim line ODD or B) three 2.5” storage drives (SSD/HDD) -
Supports an optional 3.5” HDD
XH97V supports installation of an optional 3.5” HDD rack for increased storage through purchase of PHD4 accessory. -
Equipped with an Intel 9 series Chipset
With integrated Intel H97 Express Chipset, the XH97V supports dual channel DDR3 1600 with up to 16GB memory (8GBx2). The devices support Gigabit LAN, SATA 6Gbps, and USB3.0 interface for superb data transfer speed. -
Greater life cycle and system stability
All the components of the highly integrated mainboard of this PC are fitted with modern solid capacitors, which offer six times the lifespan of normal capacitors and allow for operation in up to 50C ambient temperatures. -
Connect with three Full HD monitors independently
The XH97V delivers Full HD content on up to three independent screens via two display ports and one HDMI. This is great news for multi-display digital signage installers and those needing a three-screen workstation alike as it drives down the cost of an extra processor. -
Heat pipe cooling technology
The XH97V features Shuttle’s exclusive heat pipe cooling module with smart fan design. The precise vent design allows for constant air circulation between the inside and outside of the machine, resulting in high stability and low noise for long-term operation. -
Supports 2x Mini-PCIe Slots
The system features strong expandability with one full size and one half size Mini PCIe slots. This compact system can support mSATA SSD and WIFI modules, among other compatible modules. -
Supports optional VESA Mount
Designed to blend seamlessly into home and workplace environments, the XH97V is able to be mounted on the rear of LCD monitors with an optional PV02 VESA mount accessory.
- Shuttle XH97V - Slim-PC - no CPU - 0 GB - no HDD
- PC barebone - Slim-PC - UEFI BIOS
- Processor
- No CPU
- Processor Socket
- LGA1150 Socket
- RAM
- 0 GB (installed) / 16 GB (max) - DDR3 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s); SATA (SATA 3Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- No graphics
- Audio Output
- 5.1 channel surround - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- No operating system
- Black
- 20 cm x 24 cm x 7.2 cm
- 2.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- PC barebone
- Product Form Factor
- Slim-PC
- Black
Processor / Chipset
- CPU
- No CPU
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel H97 Express
RAM
- Installed Size
- 0 GB / 16 GB (max)
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
- Unbuffered, dual channel memory architecture
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 3
Storage Controller (2nd)
- SATA 3Gb/s
- Channel Qty
- 1
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
- Integrated
- Ethernet Controller
- Realtek RTL8111G
- Data Link Protocol
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 1 (free) x external 5.25" x 1/6H (Slim Line) , 1 (total) / 1 (free) x internal 2.5" x 1/6H , 1 (total) / 1 (free) x internal 2.5" x 1/8H
- Slots
- 1 (total) / 1 (free) x CPU , 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe 2.0 Half Mini Card , 1 (total) / 1 (free) x Mini PCIe 2.0/mSATA
- 4 x USB 3.0 (2 front, 2 rear) , 4 x USB 2.0 (2 front, 2 rear) , 1 x microphone - mini-jack (1 in front) , 1 x audio line-out/headphones - mini-jack (1 in front) , 1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x serial , 1 x audio line-out/headphones - mini-jack , 1 x audio line-out (rear)/microphone - mini-jack , 1 x audio line-out (center/subwoofer)/line-in - mini-jack , 1 x eSATA 3Gb/s
- UEFI BIOS
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- C-Tick, BSMI, CB, FCC, RoHS, ETL, Energy-using Products (EuP) Lot 6, EMI, Directive 73/23/EWG, Directive 89/336/EWG
- Power adapter
- Voltage Required
- Power Provided
- 90 Watt
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- 20 cm
- 24 cm
- 7.2 cm
- 2.2 kg
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
Shuttle XH97V Slim PC Intel H97 Barebone
