High-speed sportster with breathtaking performance data
When fitted with CPU, memory, graphics card and drives, this Barebone offers nothing less than the fastest Mini-PC in the world today. The Shuttle XPC Barebone SX58J3 owes its extreme performance to support from the "best Intel Desktop processors of all time", the Core i7 series. Two PCI-Express slots accommodate high-end graphics cards - with even large dual-slot models fitting with no problem. 16 GB DDR3 RAM can be installed in the four memory slots. There is also room for two hard disks and an optical drive inside the chassis. Uninterruptible connections are made possible thanks to two Gigabit network ports. The harmonious interaction of all components is ensured by an Intel X58 Express chipset, which easily caters for high-performance systems. The 80-PLUS-certified 500W power supply unit provides the necessary energy and the patented heatpipe cooling system guarantees maximum stability.
![]() | High-performance processor from the market leader The faster, intelligent multi-core technology of the Intel Core i7 processor employs its processing power exactly where it's most urgently needed, providing an incredible breakthrough in PC performance. This probably makes it the best Desktop processor in the world. | |
![]() | 8-channel HD audio The superior high-definition sound with digital SPDIF output not only gives that perfect cinema feeling at home, it also offers optimal sound quality for your Skype VOIP telephone conferencing. Conveniently located ports ensure ultimate user friendliness. | |
![]() | Dual-slot graphic cards? No problem! The creative engineers at Shuttle have worked out how to fit large and incredibly powerful dual-slot graphics cards into this compact PC. The special dimensions of the cards and the unusual fan size cause no problems at all in this Mini-PC. | |
![]() | Intelligent cooling Shuttle's patented Heatpipe Cooling technology with variable speed control automatically ensures maximum system stability and quiet operation in this aluminium Shuttle Mini-PC. Instead of swirling around the chassis, as is the case with conventional solutions, the warm air is specifically transferred out of the chassis. | |
![]() | Cleverly hidden In this model the ports and drives are hidden behind moveable panels that offer ideal protection from dust and ensure a clean, harmonious look. Not everyone needs to be able to see just what your Mini-PC can do. | |
![]() | Breathtaking 3D graphics and increased screen area Really impressive 3D graphics performance can be achieved with modern graphics cards in the two PCI-E 2.0 slots. Gamers appreciate the high frame rates when using two graphics cards linked by CrossFire and professional users welcome the benefit of up to four monitors. | |
![]() | Almost limitless memory In this age of terabyte hard disks, three internal ports with SATA2 offer almost unlimited hard disk space. A major benefit here is that the Serial-ATA cables interfere far less with the air flow than PATA-Standard cables. | |
![]() | External eSATA port With this interface external hard drives can reach the same speeds as inbuilt versions. Just give it a try. | |
![]() | For a longer life and more system stability All the components of the highly integrated mainboard of this PC are fitted with modern solid capacitors, which offer six times the lifespan of normal capacitors. | |
![]() | A match for software heavyweights With up to 16 GB of triple-channel DDR3 memory, this compact aluminium powerhouse is able to cope with the most demanding professional applications and all levels of complex games quickly and without breaking sweat. | |
![]() | Generous supply of USB ports You can never have enough of those versatile USB ports. This Shuttle Mini-PC offers 10 ports, with further ports for internal expansions located on the mainboard. | |
![]() | High connectivity Limitless connection options. Almost any external device can be connected to this Mini-PC via USB, FireWire or eSATA, e.g. digital cameras, video cameras and external hard drives. | |
![]() | Pre-assembled cabling saves time The most important power and data cables are already routed and just have to inserted into the relevant components. This saves valuable time when setting up the system. | |
![]() | Full support for Windows 7 Shuttle provides all the necessary drivers to ensure the smooth installation of Windows 7, and the enhanced 3D “Aero” interface runs without problem thanks to the integrated state-of-the-art graphics processor. | |
![]() | Now with improved airflow The latest Mini-PCs feature more air intake points to improve the inflow of cool air. The size and position of these intake points on the chassis cover and underside have been chosen to allow optimal cooling of all critical components, resulting in increased stability and longer lifespan |
