Economic entry-level Mini-Barebone
This Mini-PC Barebone is the first offspring of Shuttle's new J series and has been completely redesigned from top to bottom. It combines for the first time the features of various entry-level models to enable the widest possible spectrum of applications. Uncompromising reliability and maximum compatibility are guaranteed by the G41 Express Chipset. SG41J1 supports up to 8 GB of dual channel DDR3 memory and modern Intel Celeron and Core 2 processors with up to four cores. An Intel GMA X4500 graphics processor that supports DirectX-10 is already integrated. In addition to USB, PS/2, parallel and COM ports, the SG41J1 also offers one PCI-Express X16 and one PCI expansion slot.
Chassis
- J1-type chassis made of steel, color: black
- Storage bays: 1x 13.5cm (5.25") external, 2x 8.9cm (3.5") internal
- Dimensions: 32.5 x 21.5 x 19 cm (LWH) = 13.3 liters
- Weight: 7.0 kg net, 7.5 kg gross
- 9.2cm rpm-controlled system fan with 4 pin connector
- Kensington Security Slot at the back panel (also called a K-Slot or Kensington lock) as a part of an anti-theft system
Mainboard
- Shuttle FG41 V2.0, Shuttle form factor
- Proprietary mainboard design for Shuttle XPC Barebone SG41J1 Plus
- Chipset: Intel G41 Express + ICH7 (TDP: 24W + 3.3W)
BIOS
- AMI legacy core
- SPI interface, 8MB Flash ROM
- Supports PnP, ACPI 3.0
- Supports external USB flash memory card boot up
Power supply
- 250 Watt mini power supply unit
- Input voltage range: 100~240V
- Connectors: 20-pin ATX, 4-pin ATX12V
- Active PFC (Power Factor Correction)
Processor support
- Socket 775
- Supports Intel Core 2 Quad, Core 2 Duo, Pentium Dual Core, Celeron Dual-Core, Celeron 4xx
- Spports 800, 1066 or 1333 MHz front side bus (FSB)
- Maximum power consumption: TDP = 95W max.
- Processors with 533MHz FSB are not supported.
- Please refer to the support list for detailed processor support information.
Processor cooling
- Processor cooling is not included
- Please purchase an Intel boxed processor, which includes an processor cooler.
- The maximum cooler dimensions are 7.5 x 7.5 x 8 cm
- The mainboard supports temperature-controlled RPM fan speed by the BIOS.
Memory support
- 2 x 240 pin DIMM memory slots
- Supports Dual Channel
- Supports DDR3-800/1066 (PC3-6400/8500) unbuffered SDRAM memory
- Up to a total size of 8 GB, max. 4 GB per DIMM
Slots
- 1 x PCI-Express x16 v1.0 (for graphics cards only)
- 1 x PCI (32 Bit)
- Supports Dual-slot (double-width) PCI Express x16 graphics cards, however, you cannot use the PCI slot in this case. *
- If a discrete graphics card is used, the onboard graphics will be deactivated.
Integrated Graphics
- Intel Graphics Media Accelerator X4500 (GMA X4500)
- Supports Microsoft DirectX 10, Shader Model 4.0 und OpenGL 2.0
- Supports Intel Clear Video Technology with ProcAmp color control
- Maximum DVI resolution: 2048x1536
- Max. shared video memory size (UMA): 1759MB**)
Integrated Audio
- Audio Codec: IDT 92HD89C, 5.1 channel
- Three analog audio connectors (3.5mm) at the Back-Panel:
- 1) Front Line out (head phone)
- 2) Rear Surround line-out
- 3) Center line-out
- Front panel: microphone input and head phone output
Gigabit LAN Controller
- Marvell 88E8057 Ethernet network controller (Gigabit)
- Supports 100 / 1.000 MBit/s operation (100Base-TX/1000Base-T)
- Supports Wake-on-LAN (WOL)
Drive connectors
- 3x Serial-ATA II, 3 Gbit/s (300 MB/s) bandwidth
- 1 x IDE ATA 100 drives
- Pre-installed cables: 1x SATA, 1x IDE
Front Panel connectors
- Microphone (3,5 mm)
- Headphone /Line-out (3,5 mm)
- 2x USB 2.0 (Hi-Speed)
- Power button
- Power on LED (blue)
- Hard disk read/write LED (orange)
Back Panel connectors
- DVI-D output (24 pin, digital)
- 4x USB 2.0 (Hi-Speed)
- GigaBit LAN (RJ45)
- PS/2 keyboard (6-pol. Mini-DIN)
- PS/2 mouse (6-pol. Mini-DIN)
- Audio Line in, Line out, Microphone
- Clear CMOS button
- Serial and parallel port *)
Other onboard connectors
- 2x fan connectors for system and CPU fan (two 4 pin header)
- 2x USB 2.0 (2x5 pin header)
- LPC port *)
- Audio Aux-in
Accessories
- XPC Multilanguage Quick User Guide
- XPC Driver CDROM (for Windows XP, Vista 32/64 bit and Win7 32/64 bit)
- Power cord
- Pre-installed cables: 1x IDE, 1x SATA
- 4 pin Molex to SATA power cable
- Screws
*) Overclocking Warning Please note there is a certain risk involved with overclocking, including adjusting the setting in the BIOS or using third-party overclocking tools. Overclocking may affect your system stability or even cause damage of the components and devices of your system. It is done at your own risk and expense. Shuttle cannot be held responsible for possible damage caused by overclocking. ) Shared Memory Size The shared memory size is dynamically controlled by VGA driver, and the Max. shared memory size will be available only when 4GB or more memory is installed under 64-bit OS. *) Slot bracket adapter for serial and parallel ports The built-in slot bracket adapter provides one serial and one parallel port to the back panel. The cable of this adapter is connected to the onboard LPC header and the PCI expansion slot is occupied by the adapter. The adapter can easily be removed, if a PCI card or a dual-slot graphics card needs to be installed.
6-channel audio
With the inbuilt sound card you can connect up to six speakers. Get your own personal surround-sound experience at home. -
Communication in the fast lane
The integrated gigabit LAN chipset opens up completely novel possibilities for communication with no restriction on the speed of data transfer. Say goodbye to information bottlenecks, whether in the company network or for home Internet access. -
Ideal for expansion cards
Although it's been around for quite some time now, the PCI slot still remains a useful feature for connecting TV tuners, video capture cards and many other add-ons. -
PCI Express technology
A fast X16-PCI-E slot enables the use of modern 3D graphics cards and other expansion cards that have to transfer huge amounts of data at ultra-rapid speeds. -
Almost limitless memory
In this age of terabyte hard disks, three internal ports with SATA offer almost unlimited hard disk space. A major benefit here is that the Serial-ATA cables interfere far less with the air flow than PATA-standard cables. -
A match for software heavyweights
With up to 8 GB of dual-channel DDR2 memory, this compact aluminum powerhouse is able to cope with the most demanding professional applications and all levels of complex games quickly and without breaking sweat. -
Generous supply of USB ports
You can never have enough of those versatile USB ports. This Shuttle mini-PC offers 6 ports, with further ports for internal expansions located on the mainboard. -
Intelligent fan control
The Smart fan system promises low operating noise with its large, slowly rotating fans, which generate a very large airflow and have automatic variable speed control. -
Now with improved airflow
The latest mini-PCs feature more air intake points to improve the inflow of cool air. The size and position of these intake points on the chassis cover and underside have been chosen to allow optimal cooling of all critical components, resulting in increased stability and longer lifespan.
- Shuttle XPC SG41J1 - Plus - mini PC - no CPU - 0 GB - no HDD
- PC barebone - mini PC
- Processor
- No CPU
- Processor Socket
- LGA775 Socket
- RAM
- 0 GB (installed) / 8 GB (max) - DDR3 SDRAM
- Storage Controller
- SATA (SATA 3Gb/s); IDE (ATA-100)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel GMA X4500 Dynamic Video Memory Technology 5.0
- Audio Output
- 5.1 channel surround - integrated
- Networking
- GigE
- Power
- AC 120/230 V
- Black
- 21.5 cm x 32.5 cm x 19 cm
- 7 kg
- PC barebone
- Recommended Use
- Home use
- Product Form Factor
- Mini PC
- Black
Processor / Chipset
- CPU
- No CPU
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA775 Socket
- Chipset Type
- Intel G41 Express
- Front Side Bus
- 1333 MHz
RAM
- Installed Size
- 0 GB / 8 GB (max)
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
- Channel Qty
- 3
Storage Controller (2nd)
- 1 x IDE - integrated
- ATA-100
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Max Allocated RAM Size
- 1759 MB
- Video Interfaces
- DVI
Audio Output
- Integrated
- Sound Output Mode
- High Definition Audio
- Integrated
- Ethernet Controller
- Marvell Yukon 88E8057
- Data Link Protocol
- Fast Ethernet, Gigabit Ethernet
- Wake on LAN (WoL)
- Bays
- 1 (total) / 1 (free) x external 5.25" x 1/2H , 2 (total) / 2 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 1 (free) x CPU , 2 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCI
- 1 x microphone (1 in front) , 1 x audio line-out/headphones (1 in front) , 6 x USB 2.0 (2 front, 4 rear) , 1 x DVI-D , 1 x LAN (Gigabit Ethernet) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x audio line-out , 1 x audio line-out (rear)/line-in , 1 x audio line-out (centre/subwoofer)/microphone
- Cables Included
- Serial ATA cable , IDE cable
- Plug and Play, BSMI, CB, FCC, RoHS, Energy-using Products (EuP) Lot 6, ACPI 3.0
- Power supply
- Voltage Required
- AC 120/230 V
- Power Provided
- 250 Watt
- Power Factor Correction
- Yes (active)
- 21.5 cm
- 32.5 cm
- 19 cm
- 7 kg
