Shuttle DS61 Mini ITX Black Barebone System S1155 Intel H61 DDR3
Quicklinx: 8GPMWS00 Mfr#: DS61
Cost-effective and reliable Digital Signage communication platform
Shuttle's DS61 is a slim, but powerful x86-based Digital Signage Platform offering the best quality, performance and connectivity to meet the requirements of processing high quality digital media. DS61 helps you build an affordable media player to spice up your marketing and merchandising effectiveness at exhibitions, hotels, office lobbies, customer waiting areas, shopping malls and retail outlets - the possibilities are highly versatile. With its robust metal chassis and outstanding temperature range the DS61 is an industrial-grade signage platform designed for long-term, smooth and reliable operation.
Multiformat card reader
At last - no more searching for missing digital camera leads. Simply insert the memory card and you can access all stored photos and videos immediately.
HDMI interface
Goodbye cable spaghetti! Modern flat-screen TVs and large-format TFT screens can be connected to this Mini-PC with just a single thin cable. Often the audio output is also transferred in brilliant quality via the HDMI cable. If your Mini-PC already has a Blu-ray drive, the path to high-definition entertainment is clear.
Dual network connection
In this model two gigabit network controllers ensure maximum data transmission rates via load balancing and maximum availability via the failover function.
The fastest connection to external peripheral devices available to date
The USB 3.0 connectors of this model allow for data transfer of up to 5 Gbit/s (625 MB/s). This enables external devices such as USB hard disks to be connected and run at nearly the same speed as their internal siblings. USB 3.0 is downward compatible so that also devices of previous USB generations can be hooked up.
Pre-assembled cabling saves time
The most important power and data cables are already routed and just have to inserted into the relevant components. This saves valuable time when setting up the system.
Digital monitor output
Large TFT monitors work with extremely high resolutions. Digital technology is essential for displaying video signals in excellent quality and with no loss of performance. This Mini-PC offers a high-quality DVI monitor output.
Intel chipset inside
Play it safe with the reliable chipsets from the world's largest chip manufacturer. Intel chipsets have proven themselves over many years, have been presented with awards by the trade press and offer the best possible degree of compatibility.
Anti-theft protection
The Kensington Lock forms part of the anti-theft system. As with many other Notebooks, this Mini-PC can also be safely locked, ensuring long-term enjoyment from your Shuttle product.
You can rely on SSD
This is where an energy-saving "Solid State Drive" is put to use. This new drive technology guarantees extremely short access times, the highest data transmission rates and considerably lower energy consumption compared to conventional hard disks. SSDs have no mechanical components at all, are therefore subject to less wear and tear and consequently benefit from a longer service life.
Just 2.5" HDDs
An extremely compact PC housing offers less space for drives, that's why this Mini-PC uses slimline 2.5-inch hard disks. The advantage of this is that there's less noise, less heat generated and reduced power consumption. However small hard disks in a small housing does not have to mean less memory. Modern 2.5" HDDs are every bit as good as their 3.5" brothers.
Fan-less external power supply
A highly effective external power supply provides the Shuttle Mini-PC with its energy. And since it works without a fan, it is completely noise-free.
Optimal air flow
Warm air is transported out of the chassis by means of cleverly arranged components, which enables a large number of parts to be cooled simultaneously in the air flow. At no time can heat build up and adversely affect the stability of the system.
  • Dual display interface
    The DS61 V1.1 of built-in HDMI, DVI-I dual display output, supports 1080p Full HD high-definition digital content playback, greatly upgrade digital signage display quality, enhance customer viewing experience.
  • H61 solution of the thinnest on the market
    The DS61 V1.1 uses ultra-slim design, machine thickness of only 43 mm, and the thinnest on the market H61 solution. This space saving capability makes it easy to blend into any environment.
  • Industrial solid capacitors-high stability
    Because of the demand operating environment of the digital signage solution, DS61 V1.1 specially design to use the all industrial solid caps, high stability can be maintained for a long time operation.
  • Multiple I/O interfaces, expandable capacity
    DS61 V1.1 provides diverse I/O interface, four USB ports in the front panel, can easily link with a variety of peripheral, allow digital signage easier to build and to extend multi-application areas.
  • Dual Gigabit LAN, USB 3.0 high connectivity
    DS61 V1.1 built-in Realtek 8111E dual LAN interface, supports 10 Mb/s, 100 Mb/s, 1000 Mb/s high-speed transfer capacity, which can effectively control the network speed and built-in two groups of USB3.0 ports provide the highest 5.0 Gbps transfer rate and significantly enhance digital signage data transfer efficiency and save the operating time.
  • Energy-saving & low noise design
    The Shuttle's DS61 V1.1 system consumes less than 90 W of power in full use, built-in intelligent high efficiency heat pipe cooling system and operates with low noise, enhance the power use efficiency and reduce power consumption. The power design saves energy and money at the same time.
Shuttle DS61 v1.1 - Slim-PC - no CPU - 0 GB - no HDD
Personal computer - Slim-PC - wall mountable
0 no CPU
Processor Socket
LGA1155 Socket
RAM
0 GB (installed) / 16 GB (max) - DDR3 SDRAM
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Graphics Controller
No graphics
Audio Output
5.1 channel surround - integrated
GigE
OS Provided
No operating system
Software Included
Drivers & Utilities
19 cm x 16.5 cm x 4.3 cm
1.3 kg
Personal computer
Product Form Factor
Slim-PC
Processor / Chipset
CPU
No CPU
CPU Qty
0
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1155 Socket
Chipset Type
Intel H61 Express
RAM
Installed Size
0 GB / 16 GB (max)
DDR3 SDRAM
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Unbuffered, dual channel memory architecture
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Channel Qty
2
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
Integrated
Sound Output Mode
High Definition Audio
Integrated
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Realtek RTL8111E
Wake on LAN (WoL), PXE support, Teaming support
Bays
1 (total) / 1 (free) x internal 2.5" x 1/6H
Slots
1 (total) / 1 (free) x CPU , 2 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe Mini Card
1 x microphone - mini-jack (1 in front) , 1 x audio line-out/headphones - mini-jack (1 in front) , 1 x DVI-I , 1 x HDMI , 2 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 2 x serial , 4 x USB 2.0 (4 in front)
VESA mounting kit
Serial ATA cable
Wall mountable
Theft/Intrusion Protection
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
C-Tick, BSMI, CB, FCC, ETL, EMI
Power adapter
Power Provided
90 Watt
Operating System / Software
OS Provided
No operating system
Software
Drivers & Utilities
19 cm
16.5 cm
4.3 cm
1.3 kg
50 °C
10 - 90% (non-condensing)
