Shokz OpenRun Pro 2 - Open-ear headphones - Orange - Standard
Quicklinx: J4NSWS00 Mfr#: S820OR
Colours:
£140.84 ex VAT
£169.00 inc VAT
Shokz OpenRun Pro 2 provides astounding sound quality for sports enthusiasts, delivering up to 12 hours of superior audio. Additionally, its comfortable and secure fit offers peace of mind during use.
Standard Fit
Maximise the comfort
Shokz open-ear design is known for keeping your ears clean, and, together with DualPitch technology, substantially reducing vibrations, the headphones are now even more comfortable to wear for extended period so you can train with peace of mind.
Concert-like audio
OpenRun Pro 2's custom algorithm assigns each sound element to a dedicated driver, crafting a balanced, dynamic, and immersive 3D soundscape. And to ensure every note rings true, DRC technology silences distortion even at peak volume.
Leak-free private listening
Shokz OpenRun Pro 2’s bone conduction unit adopts an integrated design with components encased in one protective metal compartment and an acoustic sound leakage EQ adjustment algorithm to effectively control sound leakage, while DirectPitch tech minimises air conduction unit leakage for enhanced privacy.
Bone conduction driver for clear highs
Ultra-thin, all-metal bone conduction unit delivers clearer highs and full, natural mids, with a highly stabilised vibration system for a purer vocal sound.
Air conduction driver for surging bass
Larger low-frequency speaker for a more booming, deep bass. Strengthened, feather-light dome-shaped diaphgram preventing distortion even at peak volume. Enhanced amplitude to reproduce the subtlest detail of sound.
Minimise the squeeze
Enjoy total comfort with angled ear hooks that gently hug your ears and a feather-light fit with 16% less clamping force. Thanks to an expanded contact area that distributes pressure evenly and a streamlined band, OpenRun Pro 2 ensures comfort that lasts as long as your playlist.
Optimise the weight
Crafted with ultra-lightweight, high-strength material and a soft silicone finish, OpenRun Pro 2 delivers a cloud-like fit so comfortable, you'll forget you're even wearing headphones.
Crystal clear voice, minimal noise
Enjoy crystal-clear communication with a cutting-edge AI noise reduction algorithm that filters out 96.5% of the chaos. Strategically positioned dual microphones precisely capture the subtlest human voice, ensuring your every word rings true, from bustling streets to noisy cafés.
Fast & stable Bluetooth connection
OpenRun Pro 2 pairs instantly just by turning it on. Plus, with a 10 metre Bluetooth 5.3 range, you can roam freely without worrying about dropouts. Stay in the zone, not tangled in wires.
USB-C charging
A USB-C port lets you charge up with ease, whether you're using the included cable or your own. Dual protective layers and a secure charging port cover form an impenetrable barrier against water while maintaining effortless recharging.
AfterShokz - true wireless earphones with mic
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: J4NS 050790
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £58.22
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Shokz
Stock Status: Used Stock
