OpenFit Air inherits the Shokz open-ear design, providing you with enhanced fitting comfort and steadiness thanks to the exclusive Shokz Air-Earhook. Listen to your playlist with a well-balanced sound for workout routines and day-to-day life.
Hooked on comfort, innovative Shokz Air-earhook
Flexible Ni-Ti memory alloy, Wobble-free, Snug Fit-Featuring an ultra-fine 0.75mm flexible Ni-Ti memory alloy with a soft silicone finish, Shokz’ Air-Earhook design keeps your earbuds snugly in place.
Teardrop-shaped cross-section
Designed with a teardrop-shaped cross-section, the larger lower part minimises pressure during long listening sessions, and the smaller top section allows you to wear glasses effortlessly with your earbuds.
Adaptable earhook design, Flex Mode on
We just made ear hooks better with a pliable cutout design that folds around the curves of every ear - practically like a shape-shifter. And the bigger contact area adds an extra layer of stability to the mix.
Ergonomic dual-bevel design
25.5° comfy angle: by shifting the centre of gravity closer to the ear, Shokz have created a lighter-than-air feel that practically defies movement. It's not just comfort; it's peace of mind. And the end of the driver housing features an 18° bevel design, allowing the earbuds to fit deeper in your ear for a comfortably snug fit.
Shokz DirectPitch for open-ear listening
OpenFit Air is your sound done right. With exclusive DirectPitch tech, we're not just talking balanced; we're talking precise, keeping your audio where it belongs with even less sound leakage. And those specially designed tuning holes? They're all about keeping your tunes clear and natural.
Sounds so good
Packed with a custom dynamic driver unit, the OpenFit Air delivers sound akin to a 16mm prototype, while the composite diaphragm ensures balanced highs, mids, and bass. Paired with built-in Dynamic Range Control (DRC), EQ levels adapt in real-time, hitting all the right notes. Personalise your sound even more with the Shokz App and four preset EQ modes.
Smart Bass Vibes
With Shokz OpenBass Air, a proprietary low-frequency enhancement algorithm, these earbuds bring deep bass and detailed richness without unnecessary fuss. Positioned to vibe with your ear canal, they're all about that perfect bass.
Open-ear listening for transparency
Become the ultimate multitasker with Shokz's exclusive open-ear design. Stay plugged into the real world while you’re on the move, taking a breather, or managing that to-do list.
Smart mic, clear voice
With OpenFit Air, every word counts. 4 microphones play it smart, tracking your voice precisely with Adaptive Beamforming. Hear and be heard, clear as crystal.
One full charge, more listening sessions
With up to 6 hours on a single charge and a total of 28 hours with the charging case, these earbuds keep your playlists going. And for those impromptu jam sessions, a quick 10-minute charge serves up an extra 2 hours of listening time.
Featuring an ultra-fine 0.75 mm flexible Ni-Ti memory alloy with a soft silicone finish, the Air ear hook design keeps your earbuds snugly in place. -
Designed with a teardrop-shaped cross-section, the larger lower part minimizes pressure during long listening sessions, and the smaller top section allows you to wear glasses effortlessly with your earbuds. -
Adaptable ear hook design
Shokz just made ear hooks better with a pliable cutout design that folds around the curves of every ear - practically like a shape-shifter. And the bigger contact area adds an extra layer of stability to the mix. -
Meet the OpenFit Air's ergonomic dual-bevel design, straight from the genius minds at Shokz Labs. Through extensive studies and tests, they didn't just engineer a fit; they engineered a steadfast, secure, stable fit - and looking sleek from the front. -
25.5° comfy angle
By shifting the center of gravity closer to the ear, Shokz has created a lighter-than-air feel that practically defies movement. It's not just comfort; it's peace of mind. -
OpenFit Air is your sound done right. With the exclusive DirectPitch technology, it's not only balanced; it's precise, keeping your audio where it belongs with even less sound leakage. And those specially designed tuning holes? They're all about keeping your tunes clear and natural. -
Sounds so good
Packed with a custom dynamic driver unit, the OpenFit Air delivers sound akin to a 16 mm prototype, while the composite diaphragm ensures balanced highs, mids, and bass. Paired with built-in Dynamic Range Control (DRC), EQ levels adapt in real-time, hitting all the right notes. Personalize your sound in the Shokz App with four preset EQ modes. -
Smart bass vibes
With Shokz OpenBass Air, the proprietary low-frequency enhancement algorithm, these earbuds bring deep bass and detailed richness without unnecessary fuss. Positioned to vibe with your ear canal, they're all about that perfect bass. -
Sleek silverlight finish
Meticulously crafted, OpenFit Air radiates vitality with elegance. The matte silicone surface combined with a metallic silverlight ring creates a stunning visual effect that's all about the beauty of tech. -
Become the ultimate multitasker with Shokz's exclusive open-ear design. Stay plugged into the real world while you're on the move, taking a breather, or managing that to-do list. -
With OpenFit Air, every word counts. 4 microphones play it smart, tracking your voice precisely with Adaptive Beamforming. And thanks to Qualcomm cVc 8.0, background noise takes a backseat - reduced by an impressive 96.5%. -
Sweat- and water-resistant
With IP54 water and sweat resistance, your OpenFit Air is ready for anything. Splashes and spills when you're on the move? No worries! Pushing your limits with the sweatiest workouts? Go for it! -
Multipoint pairing
Master multitasking with multipoint pairing. Simultaneously syncs with two devices like laptops, smartphones, and tablets, on Android, iOS, or Windows. Seamlessly switch devices with a simple tap as you switch from homework to workouts, to taking it easy. -
Instant pairing, stable connection
Cut the cords for seamless connectivity with OpenFit Air. Feel the freedom of a 10-meter Bluetooth 5.2 range, pair your device simply by flipping open the case, and enjoy silky-smooth performance even when using a single earbud. -
Shokz App
Manage it all in one place thanks to the Shokz App. Fine-tune audio, connect dual devices, customize buttons, update firmware, and more. -
Intuitive touch controls
OpenFit Air puts control at your fingertips - literally. You can personalize your button configurations for commands that are uniquely yours. From calls to tunes, adjust everything with a double-tap or long-press.
