A brightness of 700 cd/m2 PN-U553 supports these LCD monitors in their digital signage duties. And PN-U553 monitors boast 1,920 (H) x 1,080 (V)-pixel full-HD resolution to ensure that none of the detail or visual impact is lost. Thanks to Full-HD resolution, everything from fine text to intricate graphics is stunningly crisp and clear.
PN-U553 monitor owes its exceptionally thin profiles to edge-lit LED backlighting, where LED elements are located at the edges of the panel. The stylishly thin profiles also enable attractive wall mounting.
Excellent image quality
A brightness of 700 cd/m2 PN-U553 supports these LCD monitors in their digital signage duties. And PN-U553 monitors boast 1,920 (H) x 1,080 (V)-pixel full-HD resolution to ensure that none of the detail or visual impact is lost. Thanks to Full-HD resolution, everything from fine text to intricate graphics is stunningly crisp and clear. -
Thin, lightweight design
PN-U553 monitor owes its exceptionally thin profiles to edge-lit LED backlighting, where LED elements are located at the edges of the panel. The stylishly thin profiles also enable attractive wall mounting. -
Energy efficiency
Edge-lit LED backlighting on PN-U553 monitor helps ensure reliable performance with low power consumption. In fact, PN-U553 monitor consumes significantly less energy than conventional CCFL-backlight displays. -
Choice of installation mode
PN-U553 monitor offers a choice of landscape or portrait installation, allowing customers to select the mode that best suits their display content and application. While portrait installation offers the look and impact of a poster, landscape installation puts wide images on vivid display. -
Enlarge (zoom) display mode
Multiple monitors can be grouped together to display one enlarged image, thanks to enlarge (zoom) display mode, which corrects the framing of that image to eliminate misalignment between monitors. -
Built-in speakers
Ideal for conveying audio information and playing location-appropriate background music, PN-U553 monitor features built-in 10 W + 10 W rear speakers that eliminate the need for external speakers and ensure a stylishly streamlined profile. -
Expanded connectivity
A comprehensive range of input/output terminals, including the DisplayPort interface, comes as standard on PN-U553 monitor to give customers a variety of connection possibilities. -
Power on delay
The power on delay function allows a time delay between the startup of each monitor in multi-monitor installations. This reduces the load placed on the power supply when a number of monitors are turned on at the same time. -
Fanless architecture
Fanless architecture maintains airflow and dissipates heat without the use of mechanical air-ventilation fans, which can attract dust and create noise. This fanless design also facilitates monitor maintenance. -
Built-in temperature sensor
Should the temperature inside a monitor rise, a built-in sensor will detect it, and the monitor will automatically lower the brightness level of its backlight system.
- Sharp PN-U553 PN series - 55" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p, 1080/24p
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- Technology
- UV²A
- LCD Backlight Technology
- Edge-lit LED
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V
- 130 Watt
- Power Consumption Stand by
- 4.5 Watt
- Dimensions (WxDxH) - without stand
- 125 cm x 5.7 cm x 72.1 cm
- 25 kg
- Product Type
- 130 Watt
- Diagonal Class
- 55"
- Commercial Use
- Series
- PN series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 125 cm
- 5.7 cm
- 72.1 cm
- 25 kg
Display
- LCD Display Technology
- UV²A
- Resolution
- 1920 x 1080
- Edge-lit LED
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 6.5 ms
- Split screen, Certified for 24/7 Continuous Operation, Ultraviolet-induced Multi-domain Vertical Alignment technology (UV2A), Data Signal Power Auto (DSPA)
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 200 mm
Video Features
- Supported Computer Resolutions
- 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- Serial input , LAN , HDMI input , DisplayPort input , DVI-D input , DVI-D output , VGA / component video input , Audio line-in , Component video input , Audio line-in , Audio line-out
- Power Device
- Power supply
- Input Voltage
- AC 120/230 V
- 4.5 Watt
