Sharp PNU473 47" 1920x1080 DVI HDMI DisplayPort LED Large Format Display
Quicklinx: 9J2GWS00 Mfr#: PNU473
  • 1080p
Sharp's PN-U473 professional LED display clearly has what it takes to get your message across. Designed for maximum impact, built for 24/7 durability, and sized for flexible installation, this 47 inch class display represent a dynamic indoor digital signage solution. Thin and lightweight enough to ensure an easy fit in stores, offices, and public spaces, the PN-U473 display boasts the outstanding image quality needed to deliver truly compelling signage.
Sharp PN-U473 PN series - 47" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, DisplayPort
HDCP Compatible
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control
Voltage
130 Watt
Power Consumption Stand by
0.5 Watt
108.3 cm x 5.5 cm x 62.7 cm
19 kg
130 Watt
Diagonal Class
47"
Commercial Use
Series
PN series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, DisplayPort
HDCP Compatible
Modes
Portrait mode, landscape mode, Mirror Display Mode
Dimensions
Without stand
108.3 cm
5.5 cm
62.7 cm
19 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Colour Depth
Up to 1.06 billion colours
Image Contrast Ratio
1300:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
12 ms
Certified for 24/7 Continuous Operation
Stands & Mounts
Flat Panel Mount Interface
400 x 200 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
DVI-D input , HDMI input , Component video input , DisplayPort input , Composite video input , DVI-D output , Audio line-in , LAN , Audio line-out , Serial input , Serial output
Plug and Play
Power supply
Input Voltage
0.5 Watt
20 - 80%
