Go big! With its magnificent 90" class diagonal screen size, 24/7 reliability and energy efficient full-array LED backlight, the PN-R903 is designed to meet the rigors of most any commercial display or digital signage application while captivating your audience. Add to this Sharp's UV2A photo alignment technology, local dimming technology, full 1920 x 1080 HD resolution, you have one of the largest, highest performing and most flexible displays in the industry. For versatility, performance and value, there's never been a better time to think big - and think Sharp.
Magnificent 90" class screen size
Combined with Sharp UV2A photo alignment technology helps create brilliant color images with maximum size and impact. -
Full array LED backlight
Positions energy-efficient white LEDs evenly across the entire panel for uniform brightness, enhanced reliability and greater legibility of text. -
Local Dimming technology
Offers outstanding black levels, amazing contrast, and superb energy efficiency with a contrast ratio of up to 1,000,000:1 with local dimming set to high. -
Brilliant, big screen images for digital signage
For use in public areas such as trade show exhibit halls, hotel lobbies and conference areas, airport corridors and retail locations. -
Engineered for 24/7 commercial use
Provides the reliability and durability you need for virtually any business. -
Full 1920 x 1080 (1080p) resolution
From analog RGB, digital RGB and HDTV video sources. -
Built-in 10 watts per channel stereo speakers
Eliminates need for an external audio system for many installations.
- Sharp PN-R903 90" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 90"
- Commercial Use
- Yes - digital signage
- Country Kits
- Europe
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 540p, 1035i, 576i, 576p, 1080/24p
- Video Interface
- HDMI
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight full array - local dimming
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V
- Energy Class
- Class A
- 660 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 205.5 cm x 12.2 cm x 119.7 cm
- 75 kg
- Product Type
- Energy Class
- Class A
- 660 Watt
- Diagonal Class
- 90"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 205.5 cm
- 12.2 cm
- 119.7 cm
- 75 kg
- Country Kits
- Europe
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight local dimming
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 4000:1
- Dynamic Contrast Ratio
- 1000000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Response Time
- 6 ms
- Split screen, Certified for 24/7 Continuous Operation, UV 2 A technology
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm, 600 x 600 mm
Video Features
- Analogue Video Input Signals
- PAL, SECAM, NTSC 3.58, NTSC4.43, PAL-M, PAL-N, PAL60
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- DVI-I , DVI-D output , HDMI , VGA input , Serial , LAN , Audio line-in , Audio line-out
- Power Device
- Power supply
- Input Voltage
- AC 120/230 V
- 0.5 Watt
