At 3840 x 2160 pixels (QFHD), this 80.1 cm diagonal (32" class) touch monitor boasts four times the resolution of 1080p Full HD. Users can now view the content of four HD screens on a single, seamless display. The PN-K322BH goes a step further to add multi-touch touch screen capability to the ultra-HD monitor to further expand possible applications.
- Sharp PN-K322BH - LED monitor - 32"
- LED-backlit LCD monitor - 32" - touchscreen
- Energy Class
- Class A
- Touch-screen
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160
- Brightness
- 300 cd/m²
- Contrast Ratio
- 800:1
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- DisplayPort
- Speakers
- Integrated
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Dimensions (WxDxH) - without stand
- 75 cm x 3.6 cm x 44.1 cm
- 9 kg
- Display Type
- Energy Class
- Class A
- Diagonal Size
- 32"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Per Inch
- 140
- Brightness
- 300 cd/m²
- Contrast Ratio
- 800:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 176
- Backlight Technology
- LED backlight
- 10-point multi-touch, IGZO technology
- Black
- 75 cm x 3.6 cm x 44.1 cm - without stand
- 9 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Capacitive
- DisplayPort , Serial , Headphones , USB , Audio line-in
Mechanical
- VESA Mounting Interface
- 200 x 200 mm
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 97 Watt
- Dimensions & Weight Details
- Without stand - width: 75 cm - depth: 3.6 cm - height: 44.1 cm - weight: 9 kg
- 5 °C
- 35 °C
- 20 - 80%
