The 47" class (46-15/16" diagonal) PN-E471R LCD monitor offers exceptionally high image quality and reliability for use in commercial display and digital signage applications. 24/7 certified, the thin bezel PN-E471R offers full 1920 x 1080 (1080p) resolution from analog RGB, digital RGB and HDTV video sources along with compatibility for use in both portrait and landscape modes. Fanless architecture helps ensure ultra-quiet reliable operation, and optional input/output expansion board and signage controller provide maximum flexibility. Also available is the PN-E471RP, which features an integrated protective overlay for use in high traffic areas.
- Sharp PN-E471R 47" LCD flat panel display - Full HD
- Product Type
- LCD flat panel display
- Diagonal Class
- 47"
- Country Kits
- Europe
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i, 540p, 1035i, 576i, 576p, 1080/24p
- Max Number of Screens
- 25
- Video Interface
- HDMI
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- TV Tuner
- No tuner
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V
- 260 watt
- Dimensions (WxDxH) - without stand
- 108 cm x 11.1 cm x 62.8 cm
- 25.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 260 watt
- Diagonal Class
- 47"
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Modes
- Landscape mode
- Dimensions
- Without stand
- 108 cm
- 11.1 cm
- 62.8 cm
- 25.5 kg
- Country Kits
- Europe
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Colour Depth
- Up to 1.06 billion colours
- Image Contrast Ratio
- 1000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 9 ms
- Backlight Life
- 50,000 hour(s)
- Certified for 24/7 Continuous Operation
Video Wall
- 25
Stands & Mounts
- Flat Panel Mount Interface
- 200 x 200 mm, 400 x 200 mm
Video Features
- Analogue Video Input Signals
- PAL, SECAM, NTSC 3.58, NTSC4.43, PAL-M, PAL-N, PAL60
- Supported Computer Resolutions
- 1366 x 768, 1024 x 768 (XGA), 800 x 600 (SVGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1360 x 768, 1920 x 1080, 1280 x 800, 1400 x 1050
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers
- Output Power / Total
- 20 watt
- Speakers
- 2 x main channel speaker - 10 watt
- Connector Type
- Audio line-in , HDMI input , Audio line-out , Serial
- EMC Class A
Sustainability Information
- ENERGY STAR Certified
- Power Device
- Power supply - internal
- Input Voltage
- AC 120/230 V
- Power Consumption Stand by / Sleep
- 0.7 watt
