Sennheiser Sennheiser PC 7 USB VoIP Headset
Quicklinx: 8DHCWS00 Mfr#: 504196
Just plug it in to your computer and get started talking over the Internet: the affordable PC 7 USB features super-easy USB Plug and Play. Ideal for families, this headset's single-sided wearing style lets you listen in on your surroundings while chatting, so you never miss a moment of the action around you. Developed in sturdy materials, it is almost unbreakable. Plus, the quality noise canceling microphone ensures your every word is heard regardless of the noise around you.
  • Lightweight single-sided headset
    A single ear piece for those that prefer to keep an ear free.
  • Exchangeable parts
    Replacement ear pads are available for purchase.
EPOS PC 7 USB - headset
Headset - wired
Recommended Use
Computer
Headphones Form Factor
On-ear monaural
Wired
Sound Output Mode
Mono
Audio Specifications
Frequency Response 42 - 17000 Hz - Sensitivity 95 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional
Headset - wired
62 g
Recommended Use
Computer
Audio Output
On-ear monaural
Wired
Sound Output Mode
Mono
Frequency Response
42 - 17000 Hz
Sensitivity
95 dB
Impedance
32 Ohm
Microphone
Boom
Uni-directional
Impedance
2 kOhm
Frequency Response
90 - 15000 Hz
Connector Type
USB (4 PIN USB Type A)
USB sound card
Cable Details
Headset cable - 2 m
Plug and Play
