Seiko Smart Label Printer 650
Quicklinx: 8Y56WS00 Mfr#: 42900116
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Thermal transfer
18 In Stock
£79.26 ex VAT
£95.11 inc VAT
The SLP650 Smart Label Printer prints dramatically faster than all previous models, up to almost 4 inches per second, providing you with everything you need to print crisp, clear and legible labels easily at 300 DPI resolution, one or many at a time. With highly reliable direct thermal technology, you have no ink, toner, ribbon or complicated software and label sheets to mess with. Plug the SLP650 into your Windows PC or Mac, connect to the built-in USB and you're ready to print labels up to 2-1/8" wide and 7" long. Replacing rolls and changing labels could not be easier with the new front end drop and load design. The SLP650 supports the SLP-TRAY accessory to accommodate extra large capacity label rolls for extra big labeling jobs.
Seiko Instruments Smart Label Printer 650 - label printer - direct thermal
Printer Type
Label printer - direct thermal
490 g
United Kingdom
Max Media Size
Roll (5.4 cm)
Max Resolution (B&W)
300 dpi
USB
Media Type
Address labels
3-year warranty
11.4 cm x 17.2 cm x 14.8 cm
Printer Type
United Kingdom
Printer
Wired
USB
300 dpi
Media Handling
Media Type
Address labels
Max Media Size
Roll (5.4 cm)
Media Sizes
Roll (5.4 cm)
Media Feeders
1 x manual - 1 roll - Roll (5.4 cm)
1 x USB - 4 pin USB Type B
Power adapter - external
Limited warranty - 3 years
11.4 cm
17.2 cm
14.8 cm
490 g
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (5.4 cm)
Brand: Seiko
