Seagate NAS Pro 6-bay is a high-performance network storage solution offering the easiest setup and the industry's most intuitive interface. The NAS Pro 6-bay features hardware, software and Seagate drives designed to work together seamlessly, which reduces your setup time to just a few minutes and delivers reliable performance for years to come. In addition, Seagate runs hours of extensive tests on every NAS Pro 6-bay before it leaves manufacturing facility, to further ensure the system is running at its best.
Built with the Intel dual-core processor specifically for NAS, ample memory and dual Gigabit Ethernet connections, the NAS Pro 6-bay delivers the performance needed for data-intensive business tasks, such as photo and video editing, accessing large databases, or multiple simultaneous PC/Mac backups.
Drives are the core of any high-capacity storage solution and Seagate delivers a specialized drive specifically for NAS systems. Furthermore, NAS HDD drives are rated for higher reliability than a standard desktop drive, offering more protection for your business's critical files.
SimplyRAID technology, built into the NAS OS software, will help you choose the RAID configuration that is best for your business by balancing performance, capacity and redundancy. Another benefit from the SimplyRAID technology is the ability to begin storing files and using the NAS instantly after choosing your preferred configuration. No more waiting hours or days for the RAID volume to build!
One of the best things about owning a NAS is the ability to collaborate, share and access files from anywhere when on-the-go. The Sdrive app for mobile devices keeps you connected to your files with enhanced security. All files are encrypted before they leave the NAS and the Sdrive app on your mobile device, combined with your user credentials, can decrypt and access the files.
- Seagate NAS Pro 6-Bay STDF24000200 - NAS server - 24 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 24 TB
- Installed Devices / Modules Qty
- 6 (installed) / 6 (max)
- 23.6 cm x 21.8 cm x 17 cm
- Localisation
- Middle East, Africa, Europe
- Processor
- 1 x Intel 1.7 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
- Hard Drive
- 6 x 4 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Seagate NAS OS 4
- System Requirements
- Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 24 TB
- 23.6 cm
- 21.8 cm
- 17 cm
- Built-in Devices
- Led panel
- Localisation
Processor / Memory
- Processors Installed
- 1 x Intel 1.7 GHz
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 2 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
- HDD - hot-swap
- Capacity
- 6 x 4 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
- Remote Management Protocol
- SNMP, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DFS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Dynamic DNS server, print server, IPv6 support, DFS support, SSH support, Jumbo Frames support, IPv4 support, Apple Time Machine compatible, WebDAV server, SNMP support, Precision Time Protocol (PTP)
- UPnP
- Expansion Bays
- 6 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x USB 3.0 , 1 x USB 2.0 , 2 x Ethernet 1000
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), UPS support
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 150 Watt
- Seagate NAS OS 4
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
