Seagate NAS Pro 2-bay is a high-performance network storage solution offering the easiest setup and the industry's most intuitive interface. The NAS Pro 2-bay features hardware, software and Seagate drives designed to work together seamlessly, which reduces your setup time to just a few minutes and delivers reliable performance for years to come. In addition, Seagate runs hours of extensive tests on every NAS Pro 2-bay before it leaves manufacturing facility, to further ensure the system is running at its best.
Built with the Intel dual-core processor specifically for NAS, ample memory and dual Gigabit Ethernet connections, the NAS Pro 2-bay delivers the performance needed for data-intensive business tasks, such as photo and video editing, accessing large databases, or multiple simultaneous PC/Mac backups. With powerful hardware inside, the NAS Pro 2-bay is a great multi-tasker and can run multiple NAS OS 4 add-on Apps simultaneously for increased productivity.
Drives are the core of any high-capacity storage solution and Seagate delivers a specialized drive specifically for NAS systems. Seagate NAS HDD drives, included with the NAS Pro 2-bay, are engineered to run 24 x 7 to deliver the performance needed by various business applications, yet run cooler than other drives on the market. Furthermore, NAS HDD drives are rated for higher reliability than a standard desktop drive, offering more protection for your business's critical files.
The storage volume on the NAS Pro 2-bay is preconfigured, which can save you hours of setup time compared to traditional RAID configurations. The SimplyRAID technology, built into the NAS OS software, will help you choose the RAID configuration that is best for your business by balancing performance, capacity and redundancy. Another benefit from SimplyRAID technology is the ability to begin storing files and using the NAS instantly after choosing your preferred configuration. No more waiting hours or days for the RAID volume to build!
Works at the pace of your business
Powered by the new performance-optimized Seagate NAS OS 4 and featuring a 2.13GHz dual-core Intel Atom processor coupled with 2GB of RAM, the 4-bay rackmount NAS delivers impressive file transfer performance. Plus, built-in support for iSCSI enables maximum performance and delivers additional storage for virtualized appliances on a given network. -
NAS optimized drives
The 4-bay rackmount NAS includes Seagate NAS HDD drives featuring NASWorks technology, which supports customized error recovery controls, power management and vibration tolerance for optimal performance and reliability. Adapting to the needs of small business NAS systems, Seagate NAS HDDs provide the best-performing, highest-capacity storage for 1- to 5-bay NAS systems. -
No time for downtime
SimplyRAID technology automatically manages installed drives to give you the optimal blend of capacity and redundancy. The 4-bay rackmount NAS is equipped with hot-swappable drive bays and dual Gigabit Ethernet ports to help increase uptime and keep your business running smoothly. The 4-bay rackmount NAS features a short depth chassis, allowing it to be installed in a shallow rack. This saves valuable floor space, making it the ideal storage solution for growing small businesses.
- Seagate Business Storage STDD8000200 - NAS server - 8 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 8 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 12 cm x 21.8 cm x 17 cm
- 1.75 kg ()
- Processor
- 1 x Intel 1.7 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 4 TB SATA 3Gb/s - One-Touch Backup
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 8 TB
- 12 cm
- 21.8 cm
- 17 cm
- 1.75 kg ()
- Built-in Devices
- LED lamp
Processor / Memory
- Processors Installed
- 1 x Intel 1.7 GHz
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 2 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 2 x 4 TB
- Interface Type
- SATA 3Gb/s
- One-Touch Backup
- Data Link Protocol
- NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
- Remote Management Protocol
- SNMP, HTTP, SSH
- Network Services Compatibility
- DHCP, DFS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP
- Wake on LAN (WOL), dynamic DNS server, IPv6 support, SSH support, static IP mode, IPv4 support, DLNA Media Server, WebDAV server, link aggregation trunking, SFTP server, Precision Time Protocol (PTP)
- UPnP
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap - 3.5"
- 2 x USB 3.0 , 1 x USB 2.0 , 2 x Ethernet 1000Base-TX - RJ-45
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), Mobile Transfer Protocol (MTP)
- Security Slot Type
- Kensington security slot
- IPv6 Ready
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 60 Watt
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
