Seagate NAS 4-bay is a full-featured network storage solution offering the easiest setup and the industry's most intuitive interface. The NAS 4-bay features hardware, software and Seagate drives designed to work together seamlessly, which reduces your setup time to just a few minutes and delivers reliable performance for years to come. In addition, Seagate runs hours of extensive tests on every NAS 4-bay before it leaves our manufacturing facility, to further ensure the system is running at its best.
Furthermore, NAS HDD drives are rated for higher reliability than a standard desktop drive, offering more protection for your business's critical files. Another benefit from the SimplyRAID technology is the ability to begin storing files and using the NAS instantly after choosing your preferred configuration. No more waiting hours or days for the RAID volume to build!
- Seagate NAS 4-Bay STCU16000200 - NAS server - 16 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 16 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 17.4 cm x 21.8 cm x 17 cm
- Localisation
- Middle East, Africa, Europe
- Processor
- 1 x ARM 1.2 GHz
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
- Hard Drive
- 4 x 4 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Seagate NAS OS 4
- System Requirements
- Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 16 TB
- 17.4 cm
- 21.8 cm
- 17 cm
- Localisation
Processor / Memory
- Processors Installed
- 1 x ARM 1.2 GHz
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 4 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
- Remote Management Protocol
- SNMP, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DFS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Dynamic DNS server, print server, IPv6 support, DFS support, SSH support, Jumbo Frames support, IPv4 support, Apple Time Machine compatible, WebDAV server, SNMP support, Precision Time Protocol (PTP)
- UPnP
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x USB 3.0 , 2 x Ethernet 1000
- Cables Included
- 1 x network cable
- Security lock slot (cable lock sold separately), UPS support
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 90 Watt
- Seagate NAS OS 4
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
