The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
- Seagate IronWolf ST4000VN006 - hard drive - 4 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 4 TB
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 5400 rpm
- 24x7 availability, rotation vibration sensor, Dual-Plane Balance, Error Recovery Control, Conventional magnetic recording (CMR)
- 101.85 mm x 146.99 mm x 20.2 mm
- 490 g
- 3-year warranty
- Bundled with
- 3 years Seagate Rescue Data Recovery
- Capacity
- 4 TB
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 101.85 mm
- 146.99 mm
- 20.2 mm
- 490 g
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 202 MBps
- Spindle Speed
- 5400 rpm
Reliability
- MTBF
- 1,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^14
- Load / Unload Cycles
- 600,000
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Power Consumption
- 4.8 Watt (active) , 3.96 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
- Limited warranty - 3 years
- 0 °C
- 65 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 80 g @ 2 ms
- Shock Tolerance (non-operating)
- 300 g @ 2 ms
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
J39B 051190 Condition: Opened and in good condition |
£29.84 |
Ref:
J39B 051191 Condition: Opened and in good condition |
£29.84 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
