The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
 - Seagate IronWolf ST4000VN006 - hard drive - 4 TB - SATA 6Gb/s
 - Hard drive - internal
- Capacity
 - 4 TB
- Interface
 - SATA 6Gb/s
- Data Transfer Rate
 - 600 MBps
- Buffer Size
 - 256 MB
- Spindle Speed
 - 5400 rpm
 - 24x7 availability, rotation vibration sensor, Dual-Plane Balance, Error Recovery Control, Conventional magnetic recording (CMR)
 - 101.85 mm x 146.99 mm x 20.2 mm
 - 490 g
 - 3-year warranty
- Bundled with
 - 3 years Seagate Rescue Data Recovery
- Capacity
 - 4 TB
- Interface
 - SATA 6Gb/s
- Buffer Size
 - 256 MB
 - 101.85 mm
 - 146.99 mm
 - 20.2 mm
 - 490 g
- Bundled with
Performance
- Drive Transfer Rate
 - 600 MBps (external)
- Internal Data Rate
 - 202 MBps
- Spindle Speed
 - 5400 rpm
Reliability
- MTBF
 - 1,000,000 hours
- 24x7 Operation
- Non-Recoverable Errors
 - 1 per 10^14
- Load / Unload Cycles
 - 600,000
Expansion & Connectivity
 - 1 x SATA 6 Gb/s
- Power Consumption
 - 4.8 Watt (active) , 3.96 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
 - Limited warranty - 3 years
 - 0 °C
 - 65 °C
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Shock Tolerance (operating)
 - 80 g @ 2 ms
- Shock Tolerance (non-operating)
 - 300 g @ 2 ms
