Seagate Seagate IronWolf ST4000VN006
Quicklinx: J39BWS00 Mfr#: ST4000VN006
More than 50 In Stock
£79.16 ex VAT
£94.99 inc VAT
Standard delivery Delivered within 3-5 working days
The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Seagate IronWolf ST4000VN006 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
5400 rpm
24x7 availability, rotation vibration sensor, Dual-Plane Balance, Error Recovery Control, Conventional magnetic recording (CMR)
101.85 mm x 146.99 mm x 20.2 mm
490 g
3-year warranty
Bundled with
3 years Seagate Rescue Data Recovery
4 TB
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
20.2 mm
490 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
202 MBps
Spindle Speed
5400 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Power Consumption
4.8 Watt (active) , 3.96 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
Limited warranty - 3 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
80 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: J39B 051190
Condition: Opened and in good condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £31.46
Ref: J39B 051191
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Seagate
Stock Status: Used Stock
