Seagate Seagate IronWolf ST4000VN006
Quicklinx: J39BWS00 Mfr#: ST4000VN006
More than 50 In Stock
£85.07 ex VAT
£102.08 inc VAT
Standard delivery Delivered within 3-5 working days
The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Seagate IronWolf ST4000VN006 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
5400 rpm
24x7 availability, rotation vibration sensor, Dual-Plane Balance, Error Recovery Control, Conventional magnetic recording (CMR)
101.85 mm x 146.99 mm x 20.2 mm
490 g
3-year warranty
Bundled with
3 years Seagate Rescue Data Recovery
4 TB
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
20.2 mm
490 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
202 MBps
Spindle Speed
5400 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Power Consumption
4.8 Watt (active) , 3.96 Watt (idle) , 0.5 Watt (standby) , 0.5 Watt (sleep)
Limited warranty - 3 years
65 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
80 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Brand: Seagate
