Seagate Playstation Game Drive for 4TB
Quicklinx: GX8WWS00 Mfr#: STGD4000400
Form Factor: [N/A]
Capacity: 4TB
Interface: USB 3.0
£101.09 ex VAT
£121.30 inc VAT
Clearing games from your console to make room for new ones? End the struggle and keep a massive collection with Game Drive for PS4. High-speed USB 3.0 gives you full-speed gaming - just like playing from the internal drive - so there's no need to throttle back.
  • Setup is a snap
    Plug your external Game Drive directly into any USB port on your console and you are ready to go.
  • Bring it
    The Game Drive for PS4 is portable. Load your games on one drive and take them all - everywhere. Play on your friend's console and continue your progress from your console when you return home.
  • Home or away you'll be ready
    The super-portable Game Drive for PS4 is truly plug-and-play and is built for gaming - inside and out.
Seagate Game Drive for PS4 STGD4000400 - hard drive - 4 TB - USB 3.0
Hard drive - external (portable)
4 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Power Source
USB bus
Enclosure Colour
76 mm x 113.5 mm x 20.7 mm
225 g
Worldwide
1-year warranty
Sony PlayStation 4, Sony PlayStation 4 Pro, Sony PlayStation 4 Slim
4 TB
USB 3.0
76 mm
113.5 mm
20.7 mm
225 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
PlayStation 4 system software version 4.5 or later
1 x USB 3.0 cable - external - 45.72 cm
Enclosure Material
Aluminium
Enclosure Colour
Worldwide
Limited warranty - 1 year
Form Factor: [N/A]
Capacity: 4TB
Interface: USB 3.0
Brand: Seagate
