Seagate IronWolf ST12000VN0008  Hard Drive 12TB
Quicklinx: FGGRWS00 Mfr#: ST12000VN0008
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 12TB
Spin Speed (rpm): 7200rpm
£240.46 ex VAT
£288.55 inc VAT
The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Seagate IronWolf ST12000VN0008 - hard drive - 12 TB - SATA 6Gb/s
Hard drive - internal
12 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
RV Sensor, Halogen Free, NAS compatible, 24x7 continuous operation, Dual-Plane Balance, Error Recovery Control, AgileArray
101.85 mm x 146.99 mm x 26.11 mm
690 g
3-year warranty
12 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
690 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
210 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
7.8 Watt (average) , 5 Watt (idle) , 0.8 Watt (standby) , 0.8 Watt (sleep)
Software Included
IronWolf Health Management
Limited warranty - 3 years
5 °C
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Form Factor: 3.5
Type: Hard drive
Capacity: 12TB
Brand: Seagate
