For everything NAS, there's IronWolf Pro - always on, always working. Built for multi-user environments and high workload rates, these NAS hard drives are enhanced with AgileArray technology for optimal reliability and system scalability.
                Built to maintain performanceMultiple users can confidently upload and download data on a NAS system populated with IronWolf hard drives.
                Support your businessIronWolf can handle the vibrations and high workload rates of a high-data network within a multi-bay NAS environment.
- Seagate IronWolf Pro ST4000NE001 - hard drive - 4 TB - SATA 6Gb/s
- Hard drive - internal
- Capacity
- 4 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Buffer Size
- 256 MB
- Spindle Speed
- 7200 rpm
- Hot-Plug Support, advanced format 512e, 24x7 availability, rotation vibration sensor, AgileArray
- 101.85 mm x 146.99 mm x 26.11 mm
- 643 g
- 5-year warranty
- Bundled with
- 2 years Rescue Data Recovery Service Plan
- Capacity
- 4 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 256 MB
- 101.85 mm
- 146.99 mm
- 26.11 mm
- 643 g
- Bundled with
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 214 MBps
- Average Latency
- 4.16 ms
- Spindle Speed
- 7200 rpm
Reliability
- MTBF
- 1,200,000 hours
- 24x7 Operation
- Non-Recoverable Errors
- 1 per 10^15
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
- Power Consumption
- 5.5 Watt (idle) , 9 Watt (active) , 0.6 Watt (standby) , 0.6 Watt (sleep)
- Software Included
- IronWolf Health Management
- Limited warranty - 5 years
- 5 °C
- 60 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Shock Tolerance (operating)
- 70 g @ 2 ms
- Shock Tolerance (non-operating)
- 300 g @ 2 ms
- Vibration Tolerance (non-operating)
- 3 g @ 10-500 Hz
