Seagate IronWolf Pro ST4000NE001 Hard drive 4TB 3.5" 7200 rpm
Quicklinx: FJFVWS00 Mfr#: ST4000NE001
Form Factor: 3.5
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
Spin Speed (rpm): 7200rpm
£114.10 ex VAT
£136.92 inc VAT
For everything NAS, there's IronWolf Pro - always on, always working. Built for multi-user environments and high workload rates, these NAS hard drives are enhanced with AgileArray technology for optimal reliability and system scalability.
  • Built to maintain performance
    Multiple users can confidently upload and download data on a NAS system populated with IronWolf hard drives.
  • Support your business
    IronWolf can handle the vibrations and high workload rates of a high-data network within a multi-bay NAS environment.
Seagate IronWolf Pro ST4000NE001 - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Hot-Plug Support, advanced format 512e, 24x7 availability, rotation vibration sensor, AgileArray
101.85 mm x 146.99 mm x 26.11 mm
643 g
5-year warranty
Bundled with
2 years Rescue Data Recovery Service Plan
4 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
643 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
214 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5.5 watt (idle) , 9 watt (active) , 0.6 watt (standby) , 0.6 watt (sleep)
Software Included
IronWolf Health Management
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Vibration Tolerance (non-operating)
3 g @ 10-500 Hz
Form Factor: 3.5
Type: Hard drive
Capacity: 4TB
Brand: Seagate
