For everything NAS, there's IronWolf Pro - always on, always working. Built for multi-user environments and high workload rates, these NAS hard drives offer optimal reliability and system scalability.
Built for performance
Multiple users can confidently upload and download data on a NAS system populated with IronWolf hard drives. IronWolf hard drives are equipped with RV sensors to maintain performance in multi-bay NAS enclosures. -
Support your business
A small business needs data that can thrive. IronWolf NAS hard drives can handle the vibrations and high workload rates of a high data network within a multi-RAID environment.
 - Seagate IronWolf Pro ST12000NE0008 - hard drive - 12 TB - SATA 6Gb/s
 - Hard drive - internal
- Capacity
 - 12 TB
- Form Factor
 - 3.5"
- Interface
 - SATA 6Gb/s
- Data Transfer Rate
 - 600 MBps
- Buffer Size
 - 256 MB
- Spindle Speed
 - 7200 rpm
 - 24x7 continuous operation, Hot-Plug Support, advanced format 512e, rotation vibration sensor, AgileArray
 - 101.85 mm x 146.99 mm x 26.11 mm
 - 690 g
 - 5-year warranty
- Bundled with
 - 2 years Seagate Rescue Data Recovery
- Capacity
 - 12 TB
- Form Factor
 - 3.5"
- Interface
 - SATA 6Gb/s
- Buffer Size
 - 256 MB
 - 101.85 mm
 - 146.99 mm
 - 26.11 mm
 - 690 g
- Bundled with
Performance
- Drive Transfer Rate
 - 600 MBps (external)
- Internal Data Rate
 - 250 MBps
- Average Latency
 - 4.16 ms
- Spindle Speed
 - 7200 rpm
Reliability
- MTBF
 - 1,200,000 hours
- 24x7 Operation
- Non-Recoverable Errors
 - 1 per 10^15
Expansion & Connectivity
 - 1 x SATA 6 Gb/s
- Compatible Bay
 - 3.5"
- Power Consumption
 - 5 Watt (idle) , 7.8 Watt (active) , 0.8 Watt (standby) , 0.8 Watt (sleep)
 - Limited warranty - 5 years
 - 5 °C
 - 60 °C
- Min Storage Temperature
 - -40 °C
- Max Storage Temperature
 - 70 °C
- Shock Tolerance (operating)
 - 70 g @ 2 ms
- Shock Tolerance (non-operating)
 - 250 g @ 2 ms
- Vibration Tolerance (non-operating)
 - 2.27 g @ 10-500 Hz
