Brand
Seagate IronWolf Pro 12TB Hard Drive
Quicklinx: FF7SWS00 Mfr#: ST12000NE0008
Form Factor: 3.5"
Type: Hard drive
Capacity: 12TB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£282.17 ex VAT
£338.60 inc VAT
For everything NAS, there's IronWolf Pro - always on, always working. Built for multi-user environments and high workload rates, these NAS hard drives offer optimal reliability and system scalability.
  • Built for performance
    Multiple users can confidently upload and download data on a NAS system populated with IronWolf hard drives. IronWolf hard drives are equipped with RV sensors to maintain performance in multi-bay NAS enclosures.
  • Support your business
    A small business needs data that can thrive. IronWolf NAS hard drives can handle the vibrations and high workload rates of a high data network within a multi-RAID environment.
Seagate IronWolf Pro ST12000NE0008 - hard drive - 12 TB - SATA 6Gb/s
Hard drive - internal
12 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
24x7 continuous operation, Hot-Plug Support, advanced format 512e, rotation vibration sensor, AgileArray
101.85 mm x 146.99 mm x 26.11 mm
690 g
5-year warranty
Bundled with
2 years Seagate Rescue Data Recovery
12 TB
3.5"
SATA 6Gb/s
Buffer Size
256 MB
101.85 mm
146.99 mm
26.11 mm
690 g
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
250 MBps
Average Latency
4.16 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
24x7 Operation
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Power Consumption
5 Watt (idle) , 7.8 Watt (active) , 0.8 Watt (standby) , 0.8 Watt (sleep)
Limited warranty - 5 years
5 °C
60 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Shock Tolerance (operating)
70 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Vibration Tolerance (non-operating)
2.27 g @ 10-500 Hz
Form Factor: 3.5"
Type: Hard drive
Capacity: 12TB
Brand: Seagate
Stock Status: In stock
