The Seagate Expansion desktop drive provides extra storage for your ever-growing collection of files. Instantly add space for more files, consolidate all of your files to a single location, or free up space on your computer's internal drive to help improve performance. Setup is straightforward; simply plug in the included power supply and USB cable, and you are ready to go. It is automatically recognized by the Windows or Mac operating system, so there is no software to install and nothing to configure. Saving files is easy too - just drag-and-drop. Take advantage of the fast data transfer speeds with the USB 3.0 interface by connecting to a USB 3.0 port.
- Seagate Expansion STKP10000400 - hard drive - 10 TB - USB 3.0
- Hard drive - external (desktop)
- Capacity
- 10 TB
- Interface
- USB 3.0
- Power Source
- Included AC adapter
- Enclosure Colour
- Black
- 41.9 mm x 178.75 mm x 125 mm
- 1.176 kg
- Bundled with
- Seagate Rescue Data Recovery
- Capacity
- 10 TB
- Interface
- USB 3.0
- 41.9 mm
- 178.75 mm
- 125 mm
- 1.176 kg
- Bundled with
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- OS Required
- Windows 10 or later, Apple MacOS X 10.12 or later
- Cables Included
- 1 x USB 3.0 cable - external - 45.72 cm
- Enclosure Colour
- Black
- Shipping Width
- 21.2 cm
- Shipping Depth
- 21.8 cm
- Shipping Height
- 7.7 cm
- Shipping Weight
- 1.342 kg
